Author Topic: Power Steering  (Read 11428 times)
Reply #30October 23, 2008, 08:06:37 pm
Power Steering
« Reply #30 on: October 23, 2008, 08:06:37 pm »
Quote from: "burn_your_money"
You don't need to take the strut off the car on a mk2 or a mk3. Not sure about other years. Just jack the car up, loosen off the upper strut mount, force the wheel down and you will be able to finagle the old strut bearing out and the new one in. Just watch your fingers
oh cool good to know! i did it by taking off the strut because i changed out the suspension anyways.  didn't think there was that much room to play in there.
Reply #31October 24, 2008, 12:40:13 am
  • 3468
    • McScrubbins Body Wash
Power Steering
« Reply #31 on: October 24, 2008, 12:40:13 am »
I need to do the same as i too am putting shorter, stiffer springs on.
Reply #32October 30, 2008, 07:20:09 pm
  • 3468
Power Steering
« Reply #32 on: October 30, 2008, 07:20:09 pm »
Ok, so i finally found time to poke about the power steering.
I took the pump off, there was a bolt that was very loose that hold its onto the mount....
more importantly it was VERY easy to spin with my fingers... i can just spin it by hand...
its full of fluid so there is a bit? of resistance but i can really just spin it freely ....
should i take it apart? I have a second one that didn't work either (this is the replacement that doesn't work).
If i take it apart could i fix something in it? anyone know about these pumps?
I can't afford a new one :(
Reply #33October 31, 2008, 08:47:25 am
Power Steering
« Reply #33 on: October 31, 2008, 08:47:25 am »
There's not much to them.
Take it apart to see if the vanes are all moving freely.
