Author Topic: 1.6TD oil pump upgrade/ oil baffle/windage tray more power??  (Read 13158 times)
Reply #15June 13, 2004, 10:42:23 pm
fspGTD
  • 1529
« Reply #15 on: June 13, 2004, 10:42:23 pm »
Quote from: "1985JettaTD"
will  this baffle\tray help with low end power? i am looking for a lot more low end power, is this something that will help me? if i do put this baffle on should i have an oil pres. and temp. gauge. i have an a2 Jetta and it didnt come stock with one. many thanks!
I didn't dyno test it, nor have I seen a dyno test of the windage tray.  But what I remember subjectively from installing mine is that it seems to benefit mainly at higher rpms.  That said, it certainly won't hurt power anywhere, including at lower RPMs.  I don't see why you would need an oil temp or pressure gauge to make use of the windage tray, although you might see a temperature drop with the windage tray if you had an oil temp gauge, I can't recall but wouldn't be surprised if this happened, due to oil being "whipped" more by the crank.  You can get them for about $30 if you shop around.
Jake Russell
Reply #16June 14, 2004, 11:33:26 am
fspGTD
  • 1529
« Reply #16 on: June 14, 2004, 11:33:26 am »
http://www.qualityvwparts.com/oil.html - $30 (service a little iffy here though)
www.gprparts.com (search for OEM part: '88 scirocco 16v / engine / oil baffle) - $35
Jake Russell
Reply #17June 14, 2004, 08:13:17 pm
Mikeyworks
  • 260
    • http://www28.brinkster.com/mikeyworks/
« Reply #17 on: June 14, 2004, 08:13:17 pm »
mmmmm...yummy
