General Information
Troubleshooting
getting T3 apart
Topic: getting T3 apart (Read 4454 times)
October 14, 2008, 06:48:00 pm
gldgti
getting T3 apart
October 14, 2008, 06:48:00 pm »
ok guys,
i'm rebuilding a genuine Garrett T3 from a 1.6 to put on my aaz, but i've run into a problem getting the exhaust housing off.
the turbo feels pretty good - minimal shaft play and theres no blade damage, but since i have a kit for it i thought why not rebuild it?
removed all of the turbine housing retainer bolts that hold the retainer ring on, and managed to un-sieze the housing-core union which had rusted together a bit. now i can turn that union freely, but i cant pull the housing off still. its clearly loose and theres now about 1.5mm axial movement, but it wont come off.
i'm worried about forcing it - any suggestions?
btw - wastegate is fixed to exhaust housing and doesnt connect anywhere else.
'91 Golf Cabrio 1.9TD
October 15, 2008, 12:57:08 pm
gldgti
getting T3 apart
October 15, 2008, 12:57:08 pm »
bump - surely a few of you guys have pulled apart a t3 or two...
October 16, 2008, 01:43:40 pm
gldgti
getting T3 apart
October 16, 2008, 01:43:40 pm »
anyone?
October 16, 2008, 02:17:02 pm
getting T3 apart
October 16, 2008, 02:17:02 pm »
Penetrating oil and a Brass hammer..
October 17, 2008, 04:01:13 am
gldgti
getting T3 apart
October 17, 2008, 04:01:13 am »
hmm... its been soaking in wd40 for a week...
maybe i should just be a bit more persuasive...
October 25, 2008, 10:03:17 pm
gldgti
getting T3 apart
October 25, 2008, 10:03:17 pm »
FYI - pulling apart rusty old turbo's...
finally got hte t3 apart, very easily, gently and simply: use a harmonic balancer puller!
the puller can easily be bolted onto the exhaust studs of the turbine exit, and centered perfectly over the turboshaft. you can then gently tighten the puller so as to press out the turbine/bearing assy from the tubine housing.
easy!
General Information
Troubleshooting
getting T3 apart
