Author Topic: getting T3 apart  (Read 4439 times)
October 14, 2008, 06:48:00 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
getting T3 apart
« on: October 14, 2008, 06:48:00 pm »
ok guys,
i'm rebuilding a genuine Garrett T3 from a 1.6 to put on my aaz, but i've run into a problem getting the exhaust housing off.
the turbo feels pretty good - minimal shaft play and theres no blade damage, but since i have a kit for it i thought why not rebuild it?
removed all of the turbine housing retainer bolts that hold the retainer ring on, and managed to un-sieze the housing-core union which had rusted together a bit. now i can turn that union freely, but i cant pull the housing off still. its clearly loose and theres now about 1.5mm axial movement, but it wont come off.
i'm worried about forcing it - any suggestions?
btw - wastegate is fixed to exhaust housing and doesnt connect anywhere else.
'91 Golf Cabrio 1.9TD
Reply #1October 15, 2008, 12:57:08 pm
gldgti
  • 488
getting T3 apart
« Reply #1 on: October 15, 2008, 12:57:08 pm »
bump - surely a few of you guys have pulled apart a t3 or two...
Reply #2October 16, 2008, 01:43:40 pm
gldgti
  • 488
getting T3 apart
« Reply #2 on: October 16, 2008, 01:43:40 pm »
anyone????
Reply #3October 16, 2008, 02:17:02 pm
getting T3 apart
« Reply #3 on: October 16, 2008, 02:17:02 pm »
Penetrating oil and a Brass hammer..
Reply #4October 17, 2008, 04:01:13 am
gldgti
  • 488
getting T3 apart
« Reply #4 on: October 17, 2008, 04:01:13 am »
hmm... its been soaking in wd40 for a week...
maybe i should just be a bit more persuasive...
Reply #5October 25, 2008, 10:03:17 pm
gldgti
  • 488
getting T3 apart
« Reply #5 on: October 25, 2008, 10:03:17 pm »
FYI - pulling apart rusty old turbo's...
finally got hte t3 apart, very easily, gently and simply: use a harmonic balancer puller!
the puller can easily be bolted onto the exhaust studs of the turbine exit, and centered perfectly over the turboshaft. you can then gently tighten the puller so as to press out the turbine/bearing assy from the tubine housing.
easy!
