Author Topic: 1.6 oil return line fittings?  (Read 3180 times)
October 14, 2008, 02:53:35 pm
patracy
  • 142
« on: October 14, 2008, 02:53:35 pm »
Hello,
    Just wondering if anyone knew where a aftermarket oil return line might be sold?  Mines damaged, and ebay has turned up nil on a used one.
Reply #1October 14, 2008, 03:34:34 pm
Jet A
  • 125
« Reply #1 on: October 14, 2008, 03:34:34 pm »
I am unfamiliar with oem design. Why cant you buy the appropraite fittings and a length of braided hose. may offer a quicker (and cheaper) solution.
Is it a 2 bolt flange at the top, and a pipe fitting at the bottom?
85 vw golf NA ----> 2b TD  Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
Reply #2October 14, 2008, 03:44:00 pm
patracy
  • 142
« Reply #2 on: October 14, 2008, 03:44:00 pm »
Quote from: "Jet A"
Yep it's a 2 bolt flange and pipe flange fitting at the bottom.  But I'm not sure if the bottom fitting might be some sort of metric or non AN fitting.
Reply #3October 15, 2008, 10:56:56 am
53 willys
« Reply #3 on: October 15, 2008, 10:56:56 am »
it's some crazy fine thread metric on the oil pan......I cut mine off and welded -AN fittings on my pan...then just made a good hose up at the local house of hose....
Reply #4October 15, 2008, 10:59:37 am
patracy
  • 142
« Reply #4 on: October 15, 2008, 10:59:37 am »
Crap, that's what I was afraid of.  Does anyone have one for sale?
Reply #5October 15, 2008, 11:46:03 am
patracy
  • 142
« Reply #5 on: October 15, 2008, 11:46:03 am »
Quote from: "libbybapa"
Prothe lists them on his various sites, but the item description says they are currently out of stock.  $20 for a new line...dirt cheap if they get them in stock.
Andrew
He's the one that's closed until the 22nd of Oct.
Reply #6October 15, 2008, 11:57:18 am
« Reply #6 on: October 15, 2008, 11:57:18 am »
i wonder if it would be possible to tap the 1.6 blocks for the oil return.  i don't really like oil draining below the oil level if you know what i mean  :wink:
Reply #7October 15, 2008, 01:43:53 pm
patracy
  • 142
« Reply #7 on: October 15, 2008, 01:43:53 pm »
Only if you wanted to weaken the block.
It's not an option in my case anyhow.   I'm not about to pull this thing back out just to put it back in.  (or weld anything)
Reply #8October 15, 2008, 01:50:45 pm
« Reply #8 on: October 15, 2008, 01:50:45 pm »
I'm sure it would be easy to drill tap the block and run it there.
I ran my return on my bypass oil filter to the front of the block where that block off plate is on the front of the block. On the old engines the vac pump was attatched right there so I used a plate off a old engine as my return.
I agree with jimfoo on the oil return level.
Reply #9October 15, 2008, 01:51:35 pm
« Reply #9 on: October 15, 2008, 01:51:35 pm »
Quote from: "patracy"
There is PLEANTY of area on the back of the block to make a return.
Reply #10October 15, 2008, 03:14:00 pm
« Reply #10 on: October 15, 2008, 03:14:00 pm »
I think I'll be running my turbo to the block on the next build.
I can then use a stock pan and sell the turbo pan and also not have to deal with the damn oil drain every time I drop the pan, I seem to drop the pan quite a bit for some reason.
Reply #11October 15, 2008, 09:36:33 pm
53 willys
« Reply #11 on: October 15, 2008, 09:36:33 pm »
Quote from: "jtanguay"
think the oil level is really that high once the engine is running and pumping oil through the engine?? seems like it would not..least not all the time??
Reply #12October 16, 2008, 09:42:24 am
patracy
  • 142
« Reply #12 on: October 16, 2008, 09:42:24 am »
Again, I'm not worried with the factory design.  It returning into the pan at oil level isn't a big issue as the oil pump constantly will be pulling oil back out.  The engine and all the plumbing is in place on my samurai/vw hybrid.  I'm not about to pull it out to modify it.  I guess I'll pull the hose off if I can't get a replacement from Prothe.
Unless someone knows where I can get fittings to make my own.
S-PAutomotive.com
