Author Topic: Mechanic Lifter for VW 8v Hydraulic Heads  (Read 2838 times)
October 06, 2008, 01:59:25 pm
saurkraut
  • 904
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #1October 07, 2008, 05:40:25 pm
andy2
« Reply #1 on: October 07, 2008, 05:40:25 pm »
I'm getting them for my TDI-M.The only hastle is to find a good and cheap supply of various shims?
Reply #2October 07, 2008, 07:47:06 pm
« Reply #2 on: October 07, 2008, 07:47:06 pm »
Quote from: "andy2"
looking for some high rpm power?  :twisted:
what mods must be done to run these followers??? i would actually consider them to be 'upgrades'.  anything need to be done to any oil holes etc???
Reply #3October 08, 2008, 03:12:46 am
gigaz2
  • 626
« Reply #3 on: October 08, 2008, 03:12:46 am »
remember to use a mechanical cam profile, hydraulic cam profiles are unsuitable for mech setups.
EDIT: the major advantage on going mech is that the most aggressive cam setups can be used, I don't think 210º is more than "stock" or "very mild" in cam terms.
our stock diesel timings are in the order of 190º.. why mech?
Reply #4October 08, 2008, 06:53:58 pm
andy2
« Reply #4 on: October 08, 2008, 06:53:58 pm »
Well I don't like the hydraulic lifter as it can keep the valves open under high boost and fueling (EGT's).I suspect they might be partly to blame for my exhaust valve issues.The hydraulic lifter can over extend and cannot shorten itself down to allow for expansion in the valve length as it is subjected to high EGT's. With mechanical systems the lash is fixed and can be changed between the lifter and cam to allow more clarance for high preformance applications.
With a daily driven car I'd stick to hydraulic lifter.Remember most of the newest Diesel engines today still don't use hydraulic lifters :wink: .
Reply #5October 08, 2008, 06:57:00 pm
andy2
« Reply #5 on: October 08, 2008, 06:57:00 pm »
No modifications needed for installing them you only need to get the correct thickness of shim.
Reply #6October 08, 2008, 09:50:42 pm
« Reply #6 on: October 08, 2008, 09:50:42 pm »
Quote from: "andy2"
pretty cool... in the future i might consider getting these
Reply #7October 09, 2008, 07:19:32 am
saurkraut
  • 904
« Reply #7 on: October 09, 2008, 07:19:32 am »
Well, I just sprung for a set for the 1.9 head project.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
