Valve cover, Air pressure. Blue smoke
Topic: Valve cover, Air pressure. Blue smoke (Read 2619 times)
October 05, 2008, 09:49:15 pm
Jet A
October 05, 2008, 09:49:15 pm »
How much air coming out of the tube nubbin in the top of the valve cover? IM getting a fair amount of air and some slightly tinted blue air, maybe whitish. Anyway, tracking down another in my escapade. Seems like the number 3 cylinder is burning oil. has new rings, and new valve seals. but there was a little bit of oil in the injector hole after 10 min of running. and i can see a bit of blue haze coming out the tail pipe. Obviously the rings are not 100% seated. could i be getting some oil past the rings?
Got the pump timed though....
85 vw golf NA ----> 2b TD Daily Driver
Converted to hydraulic head (Thanks zukgod1)
td04 turbo, Zex nitrous (for the big hills), PITA motor, fresh rings w/ ceramic pistons.
Custom Intake and Exhaust
Ported and polished head
Dipricol EGT, FP, Boost,
Autometer, Oil Temp, Water Pressure
October 06, 2008, 07:31:46 am
October 06, 2008, 07:31:46 am »
Are you sure you have the timing 100% correct? I thought my motor was kaput but I just had it timed way out. I was lazy and did the mark and pray method. Didn't work. Piles and piles of white/blue smoke.
Air coming out of the valve cover is normal, smoke is not. Since it's a fresh rebuild it may just be because the rings aren't seated
October 06, 2008, 10:00:36 am
October 06, 2008, 10:00:36 am »
It takes a good 5k for the rings to get fully seated.
Usually good to go as far as oil consumption goes after the first 1500 miles.
October 07, 2008, 03:41:33 pm
Jet A
October 07, 2008, 03:41:33 pm »
Pump is set at .0394"
So by the bently thats spot on for a td. granted while testing i am NA but i doubt that matters.
I am hoping its just the rings. I just didnt know how much air and slightly blue (more like a haze) smoke. I will give the rings a chance to seat and see how thing are going
October 07, 2008, 08:50:17 pm
October 07, 2008, 08:50:17 pm »
Remind me again how many miles you have on this engine ??
Couple of suggestions:
- Did you try to seat the rings... lots of short but hard pulls with time in between each one for the engine to cool ?
- using a dino oil or synthetic ?
October 09, 2008, 04:02:46 pm
Jet A
October 09, 2008, 04:02:46 pm »
Unknown on the engine.
but the rebuild has 0 miles on it. just a start up and a couple of revs to check for correct pump timing and such.
Using dino for the first 10,000. delo 400, then going to synthetic. that way i can go 40,000 miles between oil changes.....YES I CAN!!!
Got a few morethings to take care of before i do hard pulls.
October 10, 2008, 02:19:58 pm
autoholic
October 10, 2008, 02:19:58 pm »
Did you measure the cyls for roundness before installing new rings? It may take a while if your out of round to seat those rings.
