Author Topic: (long) 81 Golf GTD 1.6td CY "Hydraulic" head conve  (Read 5815 times)
October 05, 2008, 08:32:09 am
fighting_First
  • 17
« on: October 05, 2008, 08:32:09 am »
After endless hours and many threads regarding the hydraulic head conversion on a mechanical lifter CY block we completed the conversion.
This conversion was performed using a standard CY head gasket.
My question is to those of you who tinkered with this hydro conversion is simple, how many actually work?
Mine has not, after about 1 week the car seemed ok so we pushed the limit and found the car not worthy. Water Temp would rise after 80mph linear to the throttle input, no water issues other than the gauge going crazy. After about 90mph the engine would "run away" only after 90mph, let off and as the engine slowed the run away stopped, so I parked it.
Now the engine will start only with a pull, turning the key will only create clouds of grey smoke and a few kicks but no life. Give the car a pull slap it into 3rd and she runs fine. The engine will not start using starting fluid, normally spraying violent fuel into the air cleaner gets some response, nothing. Timing marks are all on key, no issues and were checked 3x.
History: 1.6td CY (Pre-Hydrohead)
Reman B-IDI Diesel Pump (timed)
Reman Garrett GT17/20 VNT Hybrid
Inj Nozzles NEW (either bosch or china bosch)
GlowPlugs (working)
Piston rings,
Crod pins
CRbearings
M-Bearings
Mechanical head was running fine although one of the inj. nozzle seats in the head cracked after many repairs not to mention the lifter shims were getting on my nerves. So we found a hydo head from a later model 1.6td filled the "oil hump" with silicone and slapped on the new hydro head
The donor hydro head was machined straight then reassembled in the same order it was torn down. The valve guides were left alone, the valves & seats were cleaned but no angular valve job was performed, everything looked good.
Did I miss the thread saying this conversion is a bad idea or is the compression low because I was to cheap to get a valve job? Possibly the wrong head gasket?
HELP
Thanks
Sean
Reply #1October 05, 2008, 08:59:34 am
gigaz2
  • 626
« Reply #1 on: October 05, 2008, 08:59:34 am »
so you put a hydraulic (oil pressure actuated) on a mechanical block without modifying the oil pump??
how is oil pressure on that setup? you do have a pressure gauge on that right?
Reply #2October 05, 2008, 09:05:48 am
fighting_First
  • 17
Correct, oh man tell me more I havent checked Oil pressure
« Reply #2 on: October 05, 2008, 09:05:48 am »
maybe thats why its getting hot?
Reply #3October 05, 2008, 09:11:11 am
fighting_First
  • 17
What part of the pump needs to be modified? The head seemed
« Reply #3 on: October 05, 2008, 09:11:11 am »
OK no lifter noise, should I pull the head or simply modify the pump?
Why the starting problem?
Thanks,
sean
Reply #4October 05, 2008, 09:44:12 am
dillenger1
  • 777
« Reply #4 on: October 05, 2008, 09:44:12 am »
Quote from: "gigaz2"
Ive got a86 hydo motor and it had the smaller oil pump(used to anyways)
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #5October 05, 2008, 09:58:05 am
fighting_First
  • 17
That does sound reassuring although it wouldnt hurt to go
« Reply #5 on: October 05, 2008, 09:58:05 am »
bigger, how to go bigger is my question?
Reply #6October 05, 2008, 10:05:41 am
fighting_First
  • 17
This would explain the oil seeping from the pan gasket and
« Reply #6 on: October 05, 2008, 10:05:41 am »
dipstick base?
Reply #7October 05, 2008, 10:27:08 am
fighting_First
  • 17
sorry, thanks I will run a compression test this week.
« Reply #7 on: October 05, 2008, 10:27:08 am »
any ideas why the car wont start hot or cold but a tow jump seems to work?
How exact does the timing mark need to be? I always use the same marks
as the mechanical head, it always started. Are the hydro heads picky when it comes to timing.
Huge help, thanks again
Sean
Reply #8October 05, 2008, 10:30:51 am
Re: sorry, thanks I will run a compression test this week.
« Reply #8 on: October 05, 2008, 10:30:51 am »
Quote from: "fighting_First"
electrical problem in the staring circuit. Either bad battery, bad starter, bad connections or bad wires. Or a combo of the above. Do a voltage drop test to try and isloate the problem
Reply #9October 05, 2008, 10:41:59 am
fighting_First
  • 17
The engine cranks hard so the starter is ok, fuel comes out
« Reply #9 on: October 05, 2008, 10:41:59 am »
of the injector tops when loose, battery is helped with a charger still no help.
The wiring of the car hasnt changed since the head swap, the starting problem came after the head swap.
There is a weak hot wire that I will replace now that you mention it.
Starting problem came before the "runaway" I believe the runaway came from a crappy injector connection or the spring is getting notchy.
Thanks,
Sean
Reply #10October 05, 2008, 12:06:58 pm
« Reply #10 on: October 05, 2008, 12:06:58 pm »
What is the timing set at? Lining up the marks does nothing for the pump
Reply #11October 05, 2008, 12:26:21 pm
gigaz2
  • 626
« Reply #11 on: October 05, 2008, 12:26:21 pm »
glowplugs prolly dead from the starting fluid, with low compression wont start without glowplugs.
aligning the timing marks only leaves it in the ballpark, enought for it to start. ( with good compression)
Reply #12October 05, 2008, 12:50:06 pm
fighting_First
  • 17
The engine wont start even if the engine is hot, the
« Reply #12 on: October 05, 2008, 12:50:06 pm »
glow plugs should not have any bearing on a hot engine, right?
After the head swap, the engine would start easy and run great, I noticed the power was slightly off but attributed this to the HydroH. Five days into driving I stopped to fill up shut off the engine then after filling it would not start. Waited 30minutes and it came to life, this problem got worse and now it will not start hot or cold unless its tow-jumped.
The starter fluid was used as a last resort, 1 time because we figured the pump was faulty. I will never do it again, but the start problem was evident prior to the S-fluid. The engine didnt start using the S-fluid does that make a difference when it comes to damaged rings?
Compression test in on the menu, thanks guys
Reply #13October 05, 2008, 12:52:32 pm
Mark(The Miser)UK
  • 1557
Re: The engine cranks hard so the starter is ok, fuel comes
« Reply #13 on: October 05, 2008, 12:52:32 pm »
Thanks,
Sean
Starting problem very likely glowplugs, also if you have a collapsed hydro, or a very lazy one, could be your problem especially with a small oil pump...
 How can a crappy injector cause runaway? Injector is dealt a metered amount of fuel once every 4 strokes, even if you stuffed an adaptor onto the end of the fuel line  12mm male to 25 male or what ever it is,  no runaway. Runaway is the burning of sump oil that is why it cannot be turned off with the solenoid.  Might get a surge from unburnt fuel every do often , but  I don't suppose one cylinder would do that :?
Mark-The-Miser-UK
Reply #14October 05, 2008, 12:55:13 pm
fighting_First
  • 17
Pump tmg was set at 1mm and was calibrated prior to the head
« Reply #14 on: October 05, 2008, 12:55:13 pm »
swap, it worked OK decent black smoke under full load but thats normal from what I hear, correct?
Possibly the timing needs another look, thanks again
