Author Topic: Smokey Delight - symptoms = diagnosis  (Read 3664 times)
September 29, 2008, 10:08:14 pm
  • 3468
    • McScrubbins Body Wash
« on: September 29, 2008, 10:08:14 pm »
A good example of terrible compression, cracks deep between valves and shot rings.
Here is my car, it is very broken.
When i start it this happens.
When it's hot it gets better
I thought those pictures were worth a laugh.
I'm building a new one. New head - bored block new pistons and a properly timed IP
Reply #1September 30, 2008, 12:50:24 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #1 on: September 30, 2008, 12:50:24 pm »
Smoke smells of diesel? Tried a set of glow plugs? Smoke smells of burning lubricant? Hmm, not so good. :roll:
Reply #2September 30, 2008, 03:18:28 pm
  • 3468
« Reply #2 on: September 30, 2008, 03:18:28 pm »
New gps. New gp system. Even when its hot when i start it, it does that.
It's just messed up beyond all repair.
Reply #3September 30, 2008, 10:27:34 pm
  • 2932
« Reply #3 on: September 30, 2008, 10:27:34 pm »
Do you have a clear fuel line betweeen the filter and injection pump?
 If you do;... see any air moving when you first start it?
Reply #4October 01, 2008, 12:04:55 am
  • 3468
« Reply #4 on: October 01, 2008, 12:04:55 am »
yeah i did. Big longg bubbles sometimes. so i got a new filter, cut the ends of the lines and put it back together snug and filled it up with diesel.
Still get the bubbles.
Reply #5October 01, 2008, 02:52:12 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #5 on: October 01, 2008, 02:52:12 am »
http://www.vwdiesel.net/phpBB/viewtopic.php?t=10588
White smoke can be unburned fuel, especially if its only on startup.  We have had trucks with sticking injectors that did this.  As mentioned, if this is the cause, you will get a strong diesel smell.  Does get rid of mosquitos though.
Calvin
91 VW Golf 1.6NA 5spd
Reply #6October 01, 2008, 12:14:29 pm
  • 3468
« Reply #6 on: October 01, 2008, 12:14:29 pm »
Hahahhaha thats awesome!
Reply #7October 01, 2008, 07:12:24 pm
morefuel
  • 9
« Reply #7 on: October 01, 2008, 07:12:24 pm »
i normally run a some tranny fluid in my diesel to help clean things out  old wise tail my dad told me hes and ex vw mechanic and  knows his diesels and  IP's pretty good
but id say that yours is past that past hope
Reply #8October 01, 2008, 07:13:48 pm
  • 3468
« Reply #8 on: October 01, 2008, 07:13:48 pm »
Hahaha i know! but good tip!!!
Reply #9October 01, 2008, 11:33:10 pm
« Reply #9 on: October 01, 2008, 11:33:10 pm »
Andrew, why do you say the bubbles are causing the smoke? :?
Reply #10October 02, 2008, 12:56:08 am
  • 3468
« Reply #10 on: October 02, 2008, 12:56:08 am »
Could be the bubbles but i don't know what to do about that anymore? I replaced everything and it still happens... much less but there are still some sometimes.
that doesn't make any sense to me.
I think it's also:
-two knocking injectors
-very poor IP timing
-very very low compression
Reply #11October 02, 2008, 07:58:59 am
arb
« Reply #11 on: October 02, 2008, 07:58:59 am »
I'd look at every junction from the filter to the tank with an eye for anyplace with seepage - it could show where the air is coming from. If none, look in the tank. The air needs to be stopped.
Reply #12October 02, 2008, 12:30:16 pm
  • 3468
« Reply #12 on: October 02, 2008, 12:30:16 pm »
Ahhhhhhhh
Thanks a lot guys. Okay...
This is what i replaced
-fuel filter
-black lines between injectors
-the main seals on the IP including the shaft one (the one that has to be pressed on)
This is what i did... probably not the brightest ideas
-removed the water sperator (my spliced/joined line is very likely the issue i realize now thanks to your kind and wise words)
-i cut the ends of all the fuel lines and put them back on and replaced hose clamps that skipped under slight load
I'm going to make something better to join those two lines. Thanks guys!
Reply #13October 02, 2008, 12:59:03 pm
arb
« Reply #13 on: October 02, 2008, 12:59:03 pm »
True, but if it was sucking air, lots of bubble as he said, I would expect when it sits long enough that the pressure equalized there should be some wetting around the leak.
