CY Engine Code, Same Head As RA/SB???
Topic: CY Engine Code, Same Head As RA/SB??? (Read 4327 times)
September 29, 2008, 02:49:27 pm
Gernster
September 29, 2008, 02:49:27 pm »
Seen a potential head for mine, but advertsied as Code CY 1982 - 1988
Mines a 1989 1.6 TD RA garret T2 watercooled & intercooled
Is it the same?
September 29, 2008, 03:10:08 pm
ilikevwdiesel
September 29, 2008, 03:10:08 pm »
the CY should have solid lifters. if your motor has solid lifters you'll be set.
My Bio
September 29, 2008, 03:23:58 pm
gigaz2
September 29, 2008, 03:23:58 pm »
there are no RA/SB mechanical lifters that I know of, but you can convert it, so, not bolt-on but usable.
September 30, 2008, 01:17:21 am
Gernster
September 30, 2008, 01:17:21 am »
ah, ok guys cheers, I need hydraulic lifters dont I.
September 30, 2008, 02:49:02 am
Mark(The Miser)UK
September 30, 2008, 02:49:02 am »
Gernster where the hell are ya?
In UK, CY was standard block for 82 to 88 AND came in mechanical block and hydraulic. So you may have hydraulic which is what you need :idea:
Mark-The-Miser-UK
September 30, 2008, 05:15:10 am
Gernster
September 30, 2008, 05:15:10 am »
Hi dude, Im in the UK (west yorkshire) and just desperate for a cylinder head!
The guy has given me the casting number:
028103373N
my head is:
068103374g
I'll see if it has solid or hydraulic lifters.
Its a skimmed, pressure tested head, but its a bit pricey fro me (£195)
I could really do woth a cheaper option. There is a full engine in my local scrappies, but he wont split and wants £150 for it.
September 30, 2008, 11:51:54 am
Mark(The Miser)UK
September 30, 2008, 11:51:54 am »
Anywhere near Skipton?
If the one in the scrappy is available I'd get that. Check to see what killed the car. If a smashup and engine turns over wth a 19mm socket then it'll be good. Probably good if you look in the coolant and that's clean.
What's wrong with your existing head?
Mark-The-Miser-UK
September 30, 2008, 01:05:19 pm
Gernster
September 30, 2008, 01:05:19 pm »
Not too far from Skipton (Huddersfield)
The scrappy motor has done 180k and the guys didnt seem to sure about the engine, although they did say it ran when it came in.
My head has cracked between all 4 valves, but also has a killer stepped crack going up into no2 compression zone, plus its probably warped as I cooked the engine on the motorway, not looking at me guages!
September 30, 2008, 04:54:56 pm
Mark(The Miser)UK
September 30, 2008, 04:54:56 pm »
I drove my mk2 Passat up the motorway for 2 miles towing a caravan with no water...head gasket failed and burst the rad pipe Thought water on my windscreen was from passing trucker with overshooting windscreen washers. Still alive...
Mark-The-Miser-UK
October 01, 2008, 01:36:04 am
Gernster
October 01, 2008, 01:36:04 am »
think Ive got a head!, (well ive paid for it now, just waiting for delivery!)
Head/valves/cam & injectors from an SB GTD engine. Hopefully be sorted for the weekend!
