Author Topic: My 1.6td/aaz head and other stuff too.  (Read 124059 times)
Reply #45October 31, 2008, 04:02:52 pm
cyrus #1
  • 360
My much anticipated 1.6td/aaz head.
« Reply #45 on: October 31, 2008, 04:02:52 pm »
According to the Bentley:
Mechanical Engines:
- 1 notch - 0.67-0.80mm
- 2 notch - 0.81-0.90mm
- 3 notch - 0.91-1.02mm
Hydraulic Engines:
- 1 notch - 0.66-0.86mm
- 2 notch - 0.87-0.90mm
Edit: I own page 4 and it looks like you should be 1 notch.  :D
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #46October 31, 2008, 04:04:47 pm
  • 3468
    • McScrubbins Body Wash
« Reply #46 on: October 31, 2008, 04:04:47 pm »
WOW.....
Oooooooooooooookay
uhhh so i've been using a 3 notch....
that explains a lot.... right?
if im meant to use a 1 notch and i've been using a 3....
and it barely starts....?
thanks cyrus
edit: jesus .... i can't believe that.
why was i so stupid and didn't make sure the prior owners had the right HG on it when it first started to have trouble starting...
I plan on running some extra boost (25 psi) arp's, metal hg, T3, big DP and exhaust. Should i go 2 notch then? or a 1 since its winter time around the corner? I want to drive it to the ski hills so it'll be cooooollllddd. a 1 notch would be good with less boost?
Suggestions? tips? I really don't know what im doing... clearly.
Reply #47October 31, 2008, 04:09:54 pm
dillenger1
  • 777
« Reply #47 on: October 31, 2008, 04:09:54 pm »
You wouldnt have been able to tell unless you take the head off.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #48October 31, 2008, 04:11:58 pm
  • 3468
« Reply #48 on: October 31, 2008, 04:11:58 pm »
i took the head off a year or two after driving it to "fix" the starting problem but i was like ...16/17 i was too dumb and uneducated to check the HG size i just figured... "well i'll get the same as this one here, (waving it in my hand) except a new one! that will fix it!"
DOH!
About the hone... I'm just going to clean it basically with the hone... get it as smooth as possible. Focus on the top as soon as the rest is smooth again. I don't intend on taking any steel off except to like bevel the "lip" at the top, if there even is one. It just feels dirty at the top.
Reply #49October 31, 2008, 04:41:31 pm
cyrus #1
  • 360
« Reply #49 on: October 31, 2008, 04:41:31 pm »
Holy smokes Ed!  I guess that's why most of the members on here recommend measuring your protrusion if have a 3 notch gasket.  Stupid lazy PO's.  :evil:
Cody
2002 Jetta TDI
Reply #50October 31, 2008, 05:17:41 pm
« Reply #50 on: October 31, 2008, 05:17:41 pm »
Get some bore gauges and measure the cylinders as outlined in the bentley. Most of the wear occurs at the top 20% of the cylinder (I think) so you don't want to focus your honing in that area. Unless your measurements tell you otherwise.
Reply #51October 31, 2008, 06:39:49 pm
  • 3468
« Reply #51 on: October 31, 2008, 06:39:49 pm »
Stupid lazy PO's
?? you mean Stupid Lazy Me?
Well i don't have those and i can't buy them so... i guess i'll just have to clean it up so i don't wreck the new rings....
I found an enormous amount of RTV in the oil pump filter mesh thing.
Reply #52November 04, 2008, 10:25:40 am
TurboJ
  • 661
« Reply #52 on: November 04, 2008, 10:25:40 am »
Quote from: "Smokey Eddy"
Well, I don't think that should really affect starting.
For what I know, most tuned TD:s have been using a 3 notch gasket
and that's the rational choice anyway, considering the added boost and all..
just my 2 cents
Jetta II 1.6 TD 'Project 200'
Reply #53November 04, 2008, 10:50:24 am
  • 3468
« Reply #53 on: November 04, 2008, 10:50:24 am »
I was thinking about that....
I thought the different sizse was purely FOR starting purposes. otherwise why would they make more than one size if it didn't matter which you used?
Reply #54November 04, 2008, 10:52:39 am
TurboJ
  • 661
« Reply #54 on: November 04, 2008, 10:52:39 am »
Well, it does affect the compression ratio, but in practice I understand it makes very little difference.
I think there are three gasket options purely to allow the exact right thickness, so that stock engines are all standardized even though the heads may differ.
Reply #55November 04, 2008, 11:35:24 am
  • 3468
« Reply #55 on: November 04, 2008, 11:35:24 am »
Oh, by the way i ended up using solvent + 600 grit to get all the soot off. I was very careful not to sand the cylinders down though ahahaha
I know it's very taboo but i got angry!!  :evil:  and it worked out ok.
Question!!!
I was able to push the pistons out the top with relative ease after i rubbed all the carbon off. There is a slight lip but if it is small enough that the rings passed over it no prob. isn't that a good sign? Or does it not really mean anything...
Reply #56November 04, 2008, 12:55:50 pm
TurboJ
  • 661
« Reply #56 on: November 04, 2008, 12:55:50 pm »
I think that's the way it should be. At least it was that way in my block which had been overhauled recently.
Reply #57November 04, 2008, 11:27:01 pm
  • 3468
« Reply #57 on: November 04, 2008, 11:27:01 pm »
Woo hoo!
Okay! so i got that freakin water pump off!!!
The bolts that hold it on were FINGER TIGHT   :?
uhhhh
so i took it off anyways and found a crispy gasket of sorts that fell apart
and the pump! with a nice looking impeller
This came with the thermostat i got... any idea's what it's for?
It's tempting to just get a new gasket and put that back on but no, i should get a new pump shouldn't i.
On the topic of vital pumps....
when should one change oil pumps? only when you get issues?
Reply #58November 05, 2008, 03:16:52 am
dillenger1
  • 777
« Reply #58 on: November 05, 2008, 03:16:52 am »
Thats the gasket for the block to pump?I dont know what that extra flange is though.
Reply #59November 05, 2008, 07:00:44 am
TurboJ
  • 661
« Reply #59 on: November 05, 2008, 07:00:44 am »
Oil pump can be measured for wear, a repair manual should have the guide measurements. Do also check the operating axle of the oil pump (along with the vacuum pump) - there's often play there, and in that case new parts are needed.
