Author Topic: No start on 92 1.6L TD  (Read 4476 times)
September 08, 2008, 07:14:27 pm
Super T
  • 23
« on: September 08, 2008, 07:14:27 pm »
This car is totally new to me, I've owned it for 3 days and it's my first diesel but my 4th VW.
I went to start it up today but it wouldn't go. I have no freakin clue what to look for. Engine cranks but doesn't start. I need someone to point me in the right direction.
1987 GTI VR6
1992 Jetta TD
Reply #1September 09, 2008, 02:52:47 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #1 on: September 09, 2008, 02:52:47 am »
Most likely cause is glow plugs.  Check for power to the bus bar.  If you have that, the plugs themselves may be bad.  Mine failed overnight, replaced all 4 (3 were bad) and car started great.
Calvin
91 VW Golf 1.6NA 5spd
Reply #2September 09, 2008, 11:29:16 pm
  • 2926
« Reply #2 on: September 09, 2008, 11:29:16 pm »
Yep, and look at the glow plug fuse.
 Also check for air in the fuel line from the filter to the injection pump.
Reply #3September 09, 2008, 11:29:36 pm
Super T
  • 23
« Reply #3 on: September 09, 2008, 11:29:36 pm »
Turned out to be terrible PO repair in glowplug wiring he had spliced in thin wire with small fuse. I fixed it up and works great now.
1987 GTI VR6
1992 Jetta TD
Reply #4September 09, 2008, 11:32:39 pm
  • 2926
« Reply #4 on: September 09, 2008, 11:32:39 pm »
That was close; we posted at the same time.
 Do I still get my points for guessing right? :D
Reply #5September 10, 2008, 12:11:03 pm
Super T
  • 23
« Reply #5 on: September 10, 2008, 12:11:03 pm »
Two points for the timing and one point for the right guess.  :D
1987 GTI VR6
1992 Jetta TD
Reply #6September 10, 2008, 06:39:35 pm
« Reply #6 on: September 10, 2008, 06:39:35 pm »
wow three points in 1 post, well done fatmobile. I believe that puts you in second place!!1!
Reply #7September 10, 2008, 10:11:38 pm
  • 2926
« Reply #7 on: September 10, 2008, 10:11:38 pm »
OK, that's fair,... the timing was the hard part.  :D
 Chaching
