General Information
Troubleshooting
No start on 92 1.6L TD
Topic: No start on 92 1.6L TD (Read 4559 times)
September 08, 2008, 07:14:27 pm
Super T
User+
September 08, 2008, 07:14:27 pm »
This car is totally new to me, I've owned it for 3 days and it's my first diesel but my 4th VW.
I went to start it up today but it wouldn't go. I have no freakin clue what to look for. Engine cranks but doesn't start. I need someone to point me in the right direction.
1987 GTI VR6
1992 Jetta TD
September 09, 2008, 02:52:47 am
clbanman
Cambridge, Ontario
September 09, 2008, 02:52:47 am »
Most likely cause is glow plugs. Check for power to the bus bar. If you have that, the plugs themselves may be bad. Mine failed overnight, replaced all 4 (3 were bad) and car started great.
Calvin
91 VW Golf 1.6NA 5spd
September 09, 2008, 11:29:16 pm
September 09, 2008, 11:29:16 pm »
Yep, and look at the glow plug fuse.
Also check for air in the fuel line from the filter to the injection pump.
September 09, 2008, 11:29:36 pm
Super T
User+
September 09, 2008, 11:29:36 pm »
Turned out to be terrible PO repair in glowplug wiring he had spliced in thin wire with small fuse. I fixed it up and works great now.
1987 GTI VR6
1992 Jetta TD
September 09, 2008, 11:32:39 pm
September 09, 2008, 11:32:39 pm »
That was close; we posted at the same time.
Do I still get my points for guessing right?
September 10, 2008, 12:11:03 pm
Super T
User+
September 10, 2008, 12:11:03 pm »
Two points for the timing and one point for the right guess.
1987 GTI VR6
1992 Jetta TD
September 10, 2008, 06:39:35 pm
September 10, 2008, 06:39:35 pm »
wow three points in 1 post, well done fatmobile. I believe that puts you in second place!!1!
September 10, 2008, 10:11:38 pm
September 10, 2008, 10:11:38 pm »
OK, that's fair,... the timing was the hard part.
Chaching
General Information
Troubleshooting
