Author Topic: 1.9TD 250hp (DYNO-MOVIE)  (Read 12423 times)
September 05, 2008, 05:28:23 am
Duzty
  • 34
« on: September 05, 2008, 05:28:23 am »
A little movie clip from a dyno run with my Golf mk2.  :lol:
255hp / 450nm...
http://www.bilgalleri.dk/html/vid_vis.asp?VideoID=19064
VW Golf mk2 1.9TD - FMIC, GT2860RS - 11mm Pump.
1/4 Mile - 13,24 :twisted:
Reply #1September 05, 2008, 05:49:53 am
carrizog60
  • 978
« Reply #1 on: September 05, 2008, 05:49:53 am »
any info on the car?
Portugal
Reply #2September 05, 2008, 07:07:43 am
Duzty
  • 34
« Reply #2 on: September 05, 2008, 07:07:43 am »
Started out with a 1.9D (NA engine).
1.9TD pump, modified with 11mm element and some other things by Bosch. 6000rpm's.
AAZ injectors.
Homemade intake manifold.
2½" FMIC with tubing.
3" Exdhaust.
Garrett G2860RS A/R0.86
40mm exten wastegate.
NOTHING canhed inside engine, yet. (And i has been used for drag race a year now :) )
Reply #3September 05, 2008, 08:48:33 am
numbnuts
  • 99
« Reply #3 on: September 05, 2008, 08:48:33 am »
More info please and pics of course, we all love pics :wink:
Reply #4September 05, 2008, 02:30:05 pm
carrizog60
  • 978
« Reply #4 on: September 05, 2008, 02:30:05 pm »
i dont understand why some people run 200hp and the heads lift and other run more 50hp and wont...
Portugal
Reply #5September 05, 2008, 02:33:30 pm
andy2
« Reply #5 on: September 05, 2008, 02:33:30 pm »
Well done,now questions :lol:
Are you using the stock camshaft?How much Boost?
Reply #6September 05, 2008, 02:38:35 pm
andy2
« Reply #6 on: September 05, 2008, 02:38:35 pm »
Quote from: "carrizog60"
Well he has a pretty big turbine housing which limits torque/hp at lower rpm.Like Dave's Franken engine the hp achieved he is done with 6000 rpm.My 200+ hp is made at 4000-5000 rpm due to different turbo's.
Reply #7September 05, 2008, 03:01:13 pm
gigaz2
  • 626
« Reply #7 on: September 05, 2008, 03:01:13 pm »
BMEP rules all engines, or is it RUINS all engines?  :lol:
can you disclose more info about this build? I'm specially interested in the valvegear and camshaft used :D
Reply #8September 05, 2008, 11:38:04 pm
MJF
  • 581
« Reply #8 on: September 05, 2008, 11:38:04 pm »
Very nice :D
Quote from: "andy2"
I had 223hp@4700rpm. But yes, it´s becouse of low end power.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #9September 05, 2008, 11:46:48 pm
MJF
  • 581
« Reply #9 on: September 05, 2008, 11:46:48 pm »
Quote from: "gigaz2"
:wink:
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #10September 06, 2008, 12:39:25 am
Duzty
  • 34
« Reply #10 on: September 06, 2008, 12:39:25 am »
I am not to good to english :)
So i try!
Standard valves and cam, from a 1Y engine.
The pump is build with a 1.9TD housing, camplate from the 1Y engine, 1mm element from a Iveco 2,5TD put together by our self :D
Bosch has made the top of the pump for us, to take i bit more rpm's.
The pump IP is set so it cant burn all the diesel when ideling, then it burns grey.
Yes it is a pretty big turbo for a diesel, but we peak at ~4500rpms at 34psi boost.
Reply #11September 06, 2008, 03:35:29 am
zaprzal
  • 160
    • turbodiesel.pl
« Reply #11 on: September 06, 2008, 03:35:29 am »
very nice :) post some photos
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #12February 17, 2009, 08:47:35 am
53 willys
« Reply #12 on: February 17, 2009, 08:47:35 am »
man i'm really looking hard at this turbo right now!!...it looks pretty laggy tho???
I wish the smaller BB garrets had hose style compressor outlets... :cry:
Reply #13February 17, 2009, 11:14:09 am
TurboJ
  • 661
« Reply #13 on: February 17, 2009, 11:14:09 am »
Quote from: "53 willys"
Cut and weld?
Jetta II 1.6 TD 'Project 200'
Reply #14February 17, 2009, 01:06:31 pm
53 willys
« Reply #14 on: February 17, 2009, 01:06:31 pm »
Quote from: "TurboJ"
Cut and weld?
yeah I guess I could....doing this would help cut cost since the GT garrets come with wastgates...
but then I would need to find a good aluminum coupler for the end of the turbo??
better yet I could just make and bolt an adapter flange for it too?!?!?!
I really like this turbos specs...
http://www.turbobygarrett.com/turbobygarrett/catelog/Turbochargers/GT25/GT2554R_471171_3.htm
