Hi there,
I have finally fitted the great 1.6tdi into my 89 Caddy, after a year of it sitting around. It was difficult to start, but I had it timed by a pro, diagnosed fuel delivery problems eventually (new filter, glow worms etc)
Opon start up, I discovered that its leaking badly from the
''part that the cable mounts to...on the top left of the pump...has two springs below it-before it enters the pump body....appears to be a plastic black outer seal/bush''
The throttle cable mount on the top has a single bolt holding it in from the top in the center, it appears to have play on this (sorry for the dumb description!!)
I dont want to dismantle it as the springs look complicated, and am worried that I will lose/mess up bits of the pump, so please feed me advice!!!
The engine is from a Golf GTD (mk2), and is the intercooled 80bhp version.
Its fitted with a Bosch pump, but I cant find any number on the body, but is different from the usual 1.6td pump (I have a spare td pump and was going to try and take the seal out, doubt its the same?)
Numbers I have found are 13B1301 by stop sol, 054 209 2 (or 3)54 B1 on the shaft end, none of which are correct, correct??
Cheers for any help, it has to be fixed asap, lost my storage space!
Andy
