Author Topic: 2009 Jetta and Jetta Sport Wagon  (Read 7953 times)
August 19, 2008, 07:17:04 am
subsonic
  • 1836
« on: August 19, 2008, 07:17:04 am »
SO I drove the new Jetta a few weeks back.  It was quite.  Had some good power.  No stick to be had, only the auto.  Sales person knew 0 about them.  I am 6'4" so even with the seat down head room / visability was somewhat of a issue.  I am hoping that without the giant sunroof there will be a bit more room.
These appear to be hitting the dealers now.  My wife drove my neighbors 2004 passat and really liked it.  She has given the green light to "start researching" a new jetta or wagon.  Anyone else drive one?  What was your impression?  What do you hear about the sport wagon's?  Looks like they might have less room than the 2004 model.
In a purely "not my car" sense, I wonder what you could get for power out of these if you went to a free flow exhaust and raised the boost.  Computer crash most likely :lol:
Reply #1August 19, 2008, 07:50:26 am
commuter boy
  • 277
« Reply #1 on: August 19, 2008, 07:50:26 am »
Fred's (www.tdiclub.com) has a bunch of threads on them, I'd check over there.
Reply #2August 19, 2008, 08:38:53 am
« Reply #2 on: August 19, 2008, 08:38:53 am »
the new ones will have the common rail, but also a particulate filter.  every once in a while it throws diesel into the exhaust to burn all the built up carbon from the particulate filter.  better for the environment, but i'd imagine it might be hell for performance mods.
Reply #3August 19, 2008, 06:17:33 pm
subsonic
  • 1836
« Reply #3 on: August 19, 2008, 06:17:33 pm »
DRIVETRAIN
Drivetrain Front wheel drive
Manual                   HGR
Transmission Gear Ratios:
1st 3.77
2nd 2.09
3rd 1.32
4th 0.98
5th 0.98
6th 0.81
Reverse 4.55
Final I 3.45
Final II 2.76
ENGINE
Type 2,0l, 4 cylinder, in-line, turbocharged direct injection, Common Rail
Bore 3.19 in 81.0 mm
Stroke 3.74 in 95.5 mm
Displacement 120.1 in3 1,968 cm3
Compression Ratio 16,5:1
Horsepower (SAE) @ rpm 140hp @ 4.000 125kW @ 4.000
Maximum torque, lbs - ft @ rpm 236lb/ft @ 1.750-2.500 rpm 320 Nm @ 1.750-2.500 rpm
Fuel Requirement Diesel
Firing Order 1-3-4-2
ENGINE DESIGN
Arrangement Front mounted, transverse
Cylinder Block Cast iron
Crank Shaft Five main bearings
Cylinder Head Aluminum alloy
Valve Train
Cooling System
Lubrication Rotary gear pump, intermediate shaft driven, oil cooler
Fuel / Air Supply Electronically controlled direct injection (EDC), turbocharger
Emissions
ELECTRICAL SYSTEM
Alternator - V/A 14/140
Battery - V/Ah 12/60
CAPACITIES
Engine Oil (with filter) 5.8 qt 5.5 L
Fuel Tank 14.5 gal 55.0 L
Cooling System 8.7 qt 8.2 L
Wiper Fluid 3.2 qt 3.0 L
STEERING
Type Rack and pinion, electro-mechanical, power assisted
Turns (lock to lock) 3.00
Turning Circle (curb to curb) 35.8 ft 10.9 m
Ratio 16,4 : 1
INTERIOR VOLUME - SAE
EPA Class Compact
Seating Capacity Five
Passenger Volume 91.7 ft³ 2.60 m³
Cargo Volume 32.8 ft³ 0.93 m³
Cargo Volume with rear seat folded 66.9 ft³ 1.89 m³
Volume 50.1 ft³ 1.42 m³ 41.6 ft³ 1.18 m³
Head Room 38.4 in 976 mm 38.1 in 969 mm
Shoulder Room 54.8 in 1,391 mm 53.1 in 1,348 mm
Leg Room 41.1 in 1,045 mm 35.5 in 901 mm
Single overhead camshaft, spur belt driven, four valves per cylinder, maintenance free
Water cooled, water pump, cross flow radiator, thermostatically controlled electric 3-
Bin 5 EPA Federal Emissions Concept, OBD II, catalytic converter, hp/lp- EGR
Reply #4August 19, 2008, 06:57:52 pm
Turbinepowered
  • 1206
« Reply #4 on: August 19, 2008, 06:57:52 pm »
Quote from: "subsonic"
DRIVETRAIN
Manual                   HGR
Final I 3.45
Final II 2.76
What does HGR and Final I/ Final II mean? Two-speed final drive?
Reply #5August 19, 2008, 07:11:14 pm
subsonic
  • 1836
« Reply #5 on: August 19, 2008, 07:11:14 pm »
I guess HGR is the tranny code.  NFI on the final 1 and 2 deal.  Did you see 4th and 5th were both .98.   :?   I drove the funky auto so I cant comment on the manual.  This info is for the tdi sport wagon.  I dont know if the tranny will be diferent than the sedan.  I got some full spec sheets via adobe from the dealer, but cant figure out how to post it with out it coming out all jumbled.
Reply #6August 19, 2008, 08:41:40 pm
« Reply #6 on: August 19, 2008, 08:41:40 pm »
1-4th are final I and 5th & 6th are final II.  my JNC 6 speed box is about that too.. works out to around 110km/h (or 65mph) @ 2k rpm.  8)
Reply #7August 19, 2008, 09:15:50 pm
Turbinepowered
  • 1206
« Reply #7 on: August 19, 2008, 09:15:50 pm »
Quote from: "jtanguay"
... Oh. That's right, it's a DSG box instead of a traditional torque-converter automatic.
So it has two final drive gear pairs? Weeeeeird. Sounds overly complex, too, why not just pick gears appropriately and only have to change them on two shafts instead of three?
Reply #8August 20, 2008, 11:56:10 pm
chittychittybangbang
  • 2
« Reply #8 on: August 20, 2008, 11:56:10 pm »
Quote from: "Turbinepowered"
DSG has less drivetrain losses and faster shifting.  I summed up all the info out there on the 2009 station wagon and sedan TDI Jetta here:
http://www.myturbodiesel.com/1000q_how_to/a5/jettachecklist.htm
It has dealer invoice price, color samples, and some youtube vids.  Hope this helps!
Reply #9August 21, 2008, 02:03:38 am
Turbinepowered
  • 1206
« Reply #9 on: August 21, 2008, 02:03:38 am »
Quote from: "chittychittybangbang"
Yeah, DSG has fewer losses relative to a "traditional" automatic, yes. But more than a standard, single clutch, twin-shaft manually shifted transmission.
I'm just wondering why they went for two FD ratios...
Reply #10August 21, 2008, 09:59:12 am
Darth Garry
  • 136
    • http://www.notinteresting.com
« Reply #10 on: August 21, 2008, 09:59:12 am »
I drove the regular Jetta.  It was quiet, peppy, and comfortable.  It had the DSG.  I could see myself in one of these ;)
Garry
All for one, and one for Awesomeness!
Reply #11August 21, 2008, 11:14:33 am
subsonic
  • 1836
« Reply #11 on: August 21, 2008, 11:14:33 am »
Nice link.  My wife and I need a second car quickly.  If it looks like the JSW will not be in for a few months we will be getting the sedan.  Hard to find one with the rear seat side airbags though.
Reply #12August 25, 2008, 04:16:01 am
subsonic
  • 1836
« Reply #12 on: August 25, 2008, 04:16:01 am »
I read on another forum that this same engine in Europe was rated at 170 and 190hp. Perhaps a different intake and different programing.  It will be interesting to see what the chip reprogramers can do with the US spec unit.  I wonder if the European units have 3 cat. converters on them?
