Author Topic: what belt setup on a tdi  (Read 3784 times)
May 27, 2005, 09:50:07 pm
hillfolk'r
  • 1532
« on: May 27, 2005, 09:50:07 pm »
what tim belt setup should i use on my tdi-m,,i could use the rabbit diesel eng. mount/pump bracket,,,or a gasser engine mount and the tdi pump bracket/w/that extra roller??i was thinkin the rabbit setup would be ok,,with the old stule tensioner,,and probably adjust the tension the old way,,any ideas?
Throttle cables ftw
Reply #1June 01, 2005, 06:27:46 pm
therabbittree
  • 299
« Reply #1 on: June 01, 2005, 06:27:46 pm »
I'm planning on using a full serpentine setup , atl, water and maybe ac..no v belt at all..as for t belt..the tdi setup with teh extra roller is nicer but both will work fine.. get soem inj lines and hold downs ..pronto..ha..later
deo
\x/ hillfolk!
Reply #2June 01, 2005, 07:29:58 pm
hillfolk'r
  • 1532
« Reply #2 on: June 01, 2005, 07:29:58 pm »
i was gonna go the rabbit setup on the v belt,,jus a 65 amp alt,for now,,but i noticed i did have a gasser engine mount layin round,sowith that,i could use the cast tdi pump mount,,but i think i may use allthe "old" style parts for now to get it running,,,,,
Throttle cables ftw
