Author Topic: My Official Build Thread! :) Updated!!!  (Read 14017 times)
Reply #30November 24, 2008, 02:35:19 pm
boosted_diesel_84
  • 216
« Reply #30 on: November 24, 2008, 02:35:19 pm »
Quote from: "arb"
Glad to see some are still hot tanking. Its the only way I know of to get all the rust can scale out of the block.
Where did you get your pistions ceramic coated ? I see you said Air Cooled did it, but I assume they sent them to someone else ?
Yea, hot tanking is deffenitly the best way, baking a block is a bad idea.
He coated my pistons, turbo housing and exhaust manifold in house, like i said he is an amazing machinist and has really good prices.
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #31November 24, 2008, 04:27:51 pm
foxracer1
  • 991
« Reply #31 on: November 24, 2008, 04:27:51 pm »
Got some final assm. pics? What charger do you have?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #32November 24, 2008, 07:12:08 pm
boosted_diesel_84
  • 216
« Reply #32 on: November 24, 2008, 07:12:08 pm »
Quote from: "foxracer1"
i will upload more pics later, turbo is a k24 that was ported, ceramic coated in and out,  assembled and balanced by G-Pop Shop in arizona, wastegate seat and valve were also ground to ensure proper seating ability. stock ex. mani that was ported, and ceramic coated in and out, and has egt probe.
Reply #33November 24, 2008, 07:24:38 pm
foxracer1
  • 991
« Reply #33 on: November 24, 2008, 07:24:38 pm »
Who coated it? most companies won't coat the inside of turbo componets.
91 S10 305 TPI T56
Reply #34November 24, 2008, 07:44:43 pm
boosted_diesel_84
  • 216
« Reply #34 on: November 24, 2008, 07:44:43 pm »
Air-Cooled Engines Plus, the same machine shop that did all my machining
Reply #35November 24, 2008, 08:22:12 pm
foxracer1
  • 991
« Reply #35 on: November 24, 2008, 08:22:12 pm »
I guess some one already asked but do they do it in house? I'm now an hour away from ACEP i tiffin right? So i may have them do some work for me.
91 S10 305 TPI T56
Reply #36December 08, 2008, 05:22:47 pm
boosted_diesel_84
  • 216
« Reply #36 on: December 08, 2008, 05:22:47 pm »
here are my flow sheets Finally, ive been really busy  so i have not had any time to post them,
my intake flow is 130, up from 107, exhaust is at 111.2 up from 98.7 and all this was done without hurting velocity but actually improving it, yea, the head could have flowed over 200 cfm easily, but it would kill velocity and run like poo poo. but i am very happy with the results, can runs amazing, night and day from before. and as you can see from my flow numbers to "TheMan53" John at Air cooled engines is very consistant, as both are heads flow almost identical. enjoy!
Reply #37December 08, 2008, 05:31:10 pm
  • 3468
    • McScrubbins Body Wash
« Reply #37 on: December 08, 2008, 05:31:10 pm »
Passenger is just down the street from me! I should apply there  :D  looks like they make neat stuff. :wink:
Reply #38December 08, 2008, 06:20:04 pm
« Reply #38 on: December 08, 2008, 06:20:04 pm »
I thought those numbers looked familiar, but they weren't mine at all. Just looked like the same paper.
As an added note the guys name is John and really great to deal with. I didn't have ANY troubles but if I would have he is the kind of guy that would have been straight up with me. I guarantee he would have called me to tell me if something was wrong rather than finding out later.
I can't wait to get mine all together...maybe this spring.
Reply #39December 09, 2008, 08:50:18 am
« Reply #39 on: December 09, 2008, 08:50:18 am »
Wow, those are decent flow numbers for stock valve size!!!  I'm actually surprised.  :D  Nice indeed!
Reply #40December 09, 2008, 05:36:20 pm
boosted_diesel_84
  • 216
« Reply #40 on: December 09, 2008, 05:36:20 pm »
yea, John is a great machinist and really knows his stuff. he is actually working a booth at the PRI show right now,
but as a side note, a few years back he did an audi 5 cyl head for me, with stock valves and cam ant it flowed almost 200 cfm, and that thing really ran awesome,  it was in an audi 90, non quattro unfortunatly, but at the track with sticky tires, the fastest i could run was a 16.5 only cause it would spin all the way thru 3rd gear and chirp 4th. i just could not get traction. i would let off as soon as it spun, and would get back on it and it would just spin again.
but on the street it was actually better, it walked a honda del sol with a JDM B18 V-Tec with headers, intake, etc. so it was a huge difference what his port work can do,
his flow bench is crazy cool, it can masure velocity, swirl, tumble, port map along with flow numbers and other things, its really cool. heres a pic of the flow bench he hand built!
Reply #41December 10, 2008, 07:52:23 pm
TurboJ
  • 661
« Reply #41 on: December 10, 2008, 07:52:23 pm »
Very nice numbers! That should make a big difference when you get it going :)
Jetta II 1.6 TD 'Project 200'
Reply #42December 11, 2008, 03:11:20 pm
boosted_diesel_84
  • 216
« Reply #42 on: December 11, 2008, 03:11:20 pm »
Quote from: "TurboJ"
actually its already going, runs awesome boosts hard and breaks the tires loose with no effort and i have not gone past 1/4 throttle while the motor is still breaking in. i have almost 500 miles on it.
