Author Topic: ip pump where's this piece go  (Read 2873 times)
July 12, 2008, 03:31:10 pm
pheonix165
  • 12
« on: July 12, 2008, 03:31:10 pm »
piece is a touch rusted around the curved edge and almost appears to be broken.
sorry bout the cell pic's: my intent was resealing the back side of the ip (the side with the fuel unions), but when i pulled the rear portion of the pump everything including the cam plate spat out at me. whilst i realize its my own fault for trying to do this with the pump still in the car i need help figuring out where this last piece goes.
atm the pump is still in the car and pretty much everything is back in place except for this one piece.
Reply #1July 12, 2008, 05:59:49 pm
oldskool rich
  • 446
« Reply #1 on: July 12, 2008, 05:59:49 pm »
its a pretty bad picture, im pretty sure thats not out of the pump
ive taken a few apart and never found a peice of rock inside :lol:
didnt know it was actualy possible to get the pump back together on the car, its hard enough in the vice wen its standing on end.
id highly recomend taking the pump off
f6squared I.D.S.T
Reply #2July 12, 2008, 07:23:11 pm
« Reply #2 on: July 12, 2008, 07:23:11 pm »
Quote from: "oldskool rich"
x2!
 If it's off anything inside the pump, it would have to be the control lever, but it doesn't look the right shape I don't think.
Reply #3July 13, 2008, 08:02:21 am
pheonix165
  • 12
« Reply #3 on: July 13, 2008, 08:02:21 am »
it was one of the pieces that was left inside the pump housing after most everything spilled out. its definitely not a rock as its bent steal (looks like one side has been sheared though)
i was trying to avoid pulling the pump again as i don't have the timing tools required to reinstall the pump. and being in canada a lot of the stuff you find online can end up costing twice as much.
at this point, if i have to pull the pump again...i'm sending it away.
thanks for the responces
Reply #4July 13, 2008, 09:39:53 am
« Reply #4 on: July 13, 2008, 09:39:53 am »
To me it looks like the piece on the top left of each lever.
Reply #5July 13, 2008, 04:00:22 pm
pheonix165
  • 12
« Reply #5 on: July 13, 2008, 04:00:22 pm »
that looks pretty much like it, why am i thinking thats a "not good" thing?
Reply #6July 13, 2008, 05:57:09 pm
« Reply #6 on: July 13, 2008, 05:57:09 pm »
That is what I was thinking Jim.
Reply #7July 13, 2008, 09:55:44 pm
pheonix165
  • 12
« Reply #7 on: July 13, 2008, 09:55:44 pm »
so is this a fatal thing or can it be ignored?
better yet, if i send the pump away will they be able to fix it?
Reply #8July 14, 2008, 03:19:25 am
dillenger1
  • 777
« Reply #8 on: July 14, 2008, 03:19:25 am »
Is it a broke off piece?It sounds like you just misplaced it.Is the metal snapped or stretch on one of the sides?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #9July 14, 2008, 06:46:36 am
« Reply #9 on: July 14, 2008, 06:46:36 am »
I'm thinking that is what the max fuel screw pushes against. Whatever it is it needs to be replaced, and I'd take the pump completely apart to make sure there are no small pieces anywhere in it.
Reply #10July 14, 2008, 07:27:11 am
pheonix165
  • 12
« Reply #10 on: July 14, 2008, 07:27:11 am »
Quote from: "dillenger1"
it looks to me to be a piece thats been broken off something. else
thanks for the help guys
