So I decided to be a renegade and tear my pump apart again tonight.
Removed it from the car and tore it apart, removed the weights from the governor, found a thinner washer for the timing advance piston and machined the cover about 1mm.
Re installed the pump and fired it up.
It raced until I turned off the key.
More info;
I installed a new fuel filter housing so the return line runs directly to the tank now instead of through the pump.
I didn't use my gauge to set the timing (don't ask) I made a mark on the mount and pump so I just lined them back up but I suspect I'll be busting it out tomorrow.
I backed the fuel screw way out until it wouldnt start then turned the idle screw way down and the throttle stop way out, still races.
WTH?
Having the return line running back to the tank like it is wont cause this will it? Would be easy to unhook to check that but I don't think that's the case? Was thinking maybe its blocked going back to the tank causing higher pump pressures.
If I had the timeing WAY to far advanced would it race at the same pump setting?
