Author Topic: Waterpump Question  (Read 7144 times)
June 12, 2008, 10:25:04 pm
Op-Ivy
  • 513
Waterpump Question
« on: June 12, 2008, 10:25:04 pm »
I just replaced my waterpump last weekend and now my car runs a little warmer than before. Just above the halfway mark compared to before when it was below halfway.
The impeller on the new pump was different than the old.
The old looked like this.
The new looked like this.
Is there a difference in performance between the two? I don't like running this warm especially with summer coming right up :P
Thanks, Matt
Reply #1June 12, 2008, 10:45:38 pm
Waterpump Question
« Reply #1 on: June 12, 2008, 10:45:38 pm »
did you replace the t-stat or no?  that should probably be changed...
the first one looks like it would flow more than the second, but the second one would have less 'drag'
Reply #2June 12, 2008, 11:17:56 pm
Op-Ivy
  • 513
Waterpump Question
« Reply #2 on: June 12, 2008, 11:17:56 pm »
Worthless as in less flow Andrew?
Less flow is exactly what I had figured! Thanks guys! Looks like I'm going in again  :D
Reply #3June 13, 2008, 05:39:19 am
Kudagra
  • 738
    • www.no-coast.com
Waterpump Question
« Reply #3 on: June 13, 2008, 05:39:19 am »
Quote from: "Op-Ivy"
who manufactures each of those pumps so the rest of us dont have to guess.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #4June 13, 2008, 07:07:59 am
Waterpump Question
« Reply #4 on: June 13, 2008, 07:07:59 am »
yea mine looks like the 'worthless' one  :cry:  where can one buy the cast impellar type???
Reply #5June 13, 2008, 07:21:50 am
clbanman
  • 705
    Cambridge, Ontario
Waterpump Question
« Reply #5 on: June 13, 2008, 07:21:50 am »
Calvin
91 VW Golf 1.6NA 5spd
Reply #6June 14, 2008, 10:53:37 am
Op-Ivy
  • 513
Waterpump Question
« Reply #6 on: June 14, 2008, 10:53:37 am »
Thanks Calvin!
Yea the Hepu one is the old one that I had. I'm not sure who the new one is made by and I can't even find a picture on the internet of the specific one.
Once I take it off I'll post with the manufacturer.
Reply #7June 14, 2008, 12:26:58 pm
Turbinepowered
  • 1206
Waterpump Question
« Reply #7 on: June 14, 2008, 12:26:58 pm »
The difference between those two pumps is the only problem I've had with AutohausAZ. I bought a "cast impeller" pump, was shipped a stamped sheet metal pump, returned it with a suggestion that they correct their listing, and got an absolutely nasty response back.
Might have been an off day, but still it's inexcusable.
Reply #8June 15, 2008, 09:38:37 pm
vixentd
  • 88
waterpump
« Reply #8 on: June 15, 2008, 09:38:37 pm »
I would have thought the same thing, however on an AAZ I changed the pump to the new style pressed tin, and my motor runs about 10 degrees cooler. We did another one also and the same results.  I would have thought the cast solid blade was better, but it does not flow better. I know one other person who has also discovered this with an aaz.
Reply #9June 23, 2008, 05:11:37 pm
Op-Ivy
  • 513
Waterpump Question
« Reply #9 on: June 23, 2008, 05:11:37 pm »
The stamped one was Hepu as well.
I guess they make both the cast iron and stamped.
Reply #10June 26, 2008, 08:09:54 am
FWD.MOTION
  • 170
Waterpump Question
« Reply #10 on: June 26, 2008, 08:09:54 am »
My 1.5L d N/a runs at Idle roughtly over half mark
while driving runs below or on half mark with both types of impeller waterpumps installed, both made by Hepu in Ger.
Im wondering if it really matters myself, I seen not change!
BASELYNE
Reply #11June 26, 2008, 09:57:04 pm
Op-Ivy
  • 513
Waterpump Question
« Reply #11 on: June 26, 2008, 09:57:04 pm »
The temperature that the car runs at will be directly affected by the thermostat. The waterpump will simply aid in cooling the engine. The better the flow, the faster the return to normal operating temperature.
I can confirm, now that I have put in a cast iron one, that it does flow better than the stamped one.
Reply #12June 27, 2008, 04:04:00 pm
Mark(The Miser)UK
  • 1557
Waterpump Question
« Reply #12 on: June 27, 2008, 04:04:00 pm »
How stiff are the impellers to turn? I guess they have to be driven and won't free spin with a flick :?:
Mark-The-Miser-UK
Reply #13June 28, 2008, 11:40:57 pm
Op-Ivy
  • 513
Waterpump Question
« Reply #13 on: June 28, 2008, 11:40:57 pm »
Both of them spun the same amount.
Correct, they don't spin freely. I think the inner seals keep too much pressure on them.
