Author Topic: Losing MAJOR amounts of oil  (Read 6654 times)
Reply #15June 09, 2008, 12:38:03 pm
The Mad Hatter
  • 85
« Reply #15 on: June 09, 2008, 12:38:03 pm »
Ok, may have found the problem.  It looks like somewhere on the oil filter flange is leaking.  See below.
I had to come in cause of the heat for a little while, i'll head back out an run her again and check it some more.  Is there a gasket behind that flange?  Could the high pressure sensor be leaking.  Can't really tell yet.[/img]
Reply #16June 09, 2008, 01:06:18 pm
« Reply #16 on: June 09, 2008, 01:06:18 pm »
yep there's a gasket
Reply #17June 09, 2008, 05:48:58 pm
The Mad Hatter
  • 85
« Reply #17 on: June 09, 2008, 05:48:58 pm »
Found it.  The sending unit for the pressure sensor is leaking out the top.  To be replaced soon.  Thanks for the help yous guys!
Reply #18December 24, 2008, 01:39:35 pm
dillenger1
  • 777
« Reply #18 on: December 24, 2008, 01:39:35 pm »
why not just tighten it?Dont use any tef tape it will isolate the ground.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #19December 31, 2008, 10:43:33 pm
Rabbit TD
  • 840
« Reply #19 on: December 31, 2008, 10:43:33 pm »
Quote from: "dillenger1"
I don't know if these VW senders will do it or not but I've seen some others leak internaly right through them and out around the pastic at the connector.
