General Information
Troubleshooting
Losing MAJOR amounts of oil
Pages:
Topic: Losing MAJOR amounts of oil (Read 6775 times)
Reply #15
June 09, 2008, 12:38:03 pm
The Mad Hatter
Reply #15 on:
June 09, 2008, 12:38:03 pm »
Ok, may have found the problem. It looks like somewhere on the oil filter flange is leaking. See below.
I had to come in cause of the heat for a little while, i'll head back out an run her again and check it some more. Is there a gasket behind that flange? Could the high pressure sensor be leaking. Can't really tell yet.[/img]
Reply #16
June 09, 2008, 01:06:18 pm
Reply #16 on:
June 09, 2008, 01:06:18 pm »
yep there's a gasket
Reply #17
June 09, 2008, 05:48:58 pm
The Mad Hatter
Reply #17 on:
June 09, 2008, 05:48:58 pm »
Found it. The sending unit for the pressure sensor is leaking out the top. To be replaced soon. Thanks for the help yous guys!
Reply #18
December 24, 2008, 01:39:35 pm
dillenger1
Reply #18 on:
December 24, 2008, 01:39:35 pm »
why not just tighten it?Dont use any tef tape it will isolate the ground.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #19
December 31, 2008, 10:43:33 pm
Rabbit TD
Reply #19 on:
December 31, 2008, 10:43:33 pm »
Quote from: "dillenger1"
I don't know if these VW senders will do it or not but I've seen some others leak internaly right through them and out around the pastic at the connector.
Pages:
General Information
Troubleshooting
