Author Topic: Advanced timings = bad??  (Read 3307 times)
May 30, 2008, 05:46:14 am
Torchd
  • 372
« on: May 30, 2008, 05:46:14 am »
Hey guys!!
I was just wondering if advanced ip timings are bad for the engine??
I fulled advanced the fuel pump timings of my friends 1,6 NA..  i dont know what the timings are now cuz i dont have a gauge.
The engine sounds a bit harsh now but it has made a lot of difference in the acceleration.
Please let me know about the adverse effects... if any.
All comments are welcome.
Thankss!
Reply #1May 30, 2008, 07:04:03 am
burnt_servo
  • 278
« Reply #1 on: May 30, 2008, 07:04:03 am »
how skilled are you at changing the headgasket ?
before you start playing you should have the tools to measure things  to know what your doing  instead of guessing .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #2May 31, 2008, 03:08:34 am
OM617
« Reply #2 on: May 31, 2008, 03:08:34 am »
Guessing is about the worst possible thing anyone can do.
Reply #3June 02, 2008, 01:08:36 am
Torchd
  • 372
« Reply #3 on: June 02, 2008, 01:08:36 am »
hmm  so the HG can leak??
The gauge is not available in my country....i'll have to get it shipped.
Shud i back off the IP timing?
Reply #4June 02, 2008, 05:30:49 pm
« Reply #4 on: June 02, 2008, 05:30:49 pm »
You won't get it back where it was, but you definitly should try and make an effort to. You can put holes in the pistons from too far advanced timing. What was the reasoning for advancing it?
Reply #5June 02, 2008, 05:41:31 pm
rallydiesel
  • 1880
« Reply #5 on: June 02, 2008, 05:41:31 pm »
At least bring it back enough to quiet the engine down. If you smoke and miss you've gone too far. I think of it this way, if it is far too advanced, the piston will ignite the fuel before reaching TDC. Think of the stress on the rods, bearings, piston tops, etc. Not good.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #6June 02, 2008, 08:44:33 pm
OM617
« Reply #6 on: June 02, 2008, 08:44:33 pm »
Too far advanced and the piston will be trying to compress the already expanding gasses. As you can imagine that puts a LOT of stress on the pistons and rods.
Reply #7June 03, 2008, 04:47:11 pm
dieselsnowmobile
  • 103
« Reply #7 on: June 03, 2008, 04:47:11 pm »
And will cause you to burn oil.  I had mine at about 1.05 mm and was burning 3.5 qts per 1,000 miles.  I put it to .95mm and it now only burns about 1 qt per 1,000.  There are probably some other issues involved, but I was amazed that it did that, so I would not advance it much past 1mm is probably the limit.
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
Reply #8June 07, 2008, 06:11:47 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #8 on: June 07, 2008, 06:11:47 pm »
Quote from: "dieselsnowmobile"
might have been because of the extra combustion pressure leaking past the rings and further pressurising the crancase...
'91 Golf Cabrio 1.9TD
Reply #9June 09, 2008, 04:39:37 pm
Zulfiqar
  • 254
« Reply #9 on: June 09, 2008, 04:39:37 pm »
speaking of Pakistan and DTI - I had a gauge adapter custom made for me by my handy machinist when I lived there, and I bought a dial gauge to stick it in the end of it - worked a doddle - and I would double the comment of blow and oil consumption too. timing really really matters for these engines.
Diesel IS the future
