Author Topic: Dammit!!!  (Read 5571 times)
May 27, 2008, 09:09:35 am
Dammit!!!
« on: May 27, 2008, 09:09:35 am »
Well my Saturday started out good but ended badly.
I emptied over 4 qts of oil out of the intercooler.
Engine started to race away just as I rounded the corner to my house, had it in 3rd (luckily) so I was able to drop the clutch and kill it before it toasted everything.
Reply #1May 27, 2008, 09:11:29 am
Dammit!!!
« Reply #1 on: May 27, 2008, 09:11:29 am »
Guess I need something a tad more robust than a k24..
Is the T3 any better?
How about a k26?
Maybe I can use the smaller exhaust housing off a k24 and use the compressor and cartridge from the k26?
Reply #2May 27, 2008, 09:46:10 am
Dr. Diesel
  • 1341
Dammit!!!
« Reply #2 on: May 27, 2008, 09:46:10 am »
how hard a corner was it? are you sure you didn't just loose oil from out the valve cover-pcv-turbo inlet?
Reply #3May 27, 2008, 10:14:32 am
Dammit!!!
« Reply #3 on: May 27, 2008, 10:14:32 am »
Look at those fins there..
The shaft is broken.. Need a stronger turbo.
The "corner" I was going around as the engine started to race was just a regular corner you would go around in a city.
This happened about a mile from home, started to ingest oil as I got home.
Reply #4May 27, 2008, 11:01:56 am
Dammit!!!
« Reply #4 on: May 27, 2008, 11:01:56 am »
Are you running too high a boost and overspeeding the turbo? If so, then maybe T3 or VNT time.
Reply #5May 27, 2008, 11:51:15 am
Dammit!!!
« Reply #5 on: May 27, 2008, 11:51:15 am »
Quote from: "jimfoo"
Ummm ya high boost and fast shifts is what killed it.
The sound of turbo bark during shifts told me I was running the boost a tad high. Like 30spi. Hit 40 a few times pre intercooler.
Was really working that suka.  I would love a VNT but I'm not to sure I want to go through the control part to get it to work.
At the moment I'm leaning towards building a K24/26 hybrid or using a T3.
If nothing else the T3 should be beefy.
Reply #6May 27, 2008, 12:08:34 pm
Dr. Diesel
  • 1341
Dammit!!!
« Reply #6 on: May 27, 2008, 12:08:34 pm »
oops. The pic of the turbo didn't load first time I read this.
Reply #7May 27, 2008, 12:28:25 pm
bert
  • 423
Dammit!!!
« Reply #7 on: May 27, 2008, 12:28:25 pm »
T3 i would go for,mines off a 86 golf td,steam cleaned and fitted on my AAZ and its good fun and its used hard  :wink:
Bert
Reply #8May 27, 2008, 12:54:10 pm
Dammit!!!
« Reply #8 on: May 27, 2008, 12:54:10 pm »
Quote from: "bert"
Bert
What are you running for fuel?
Pump
Injectors
I think the biggest thing is I'm running a 10mm pump with a 1.9idi camplate in it.
Merc nozzles as well.
Reply #9May 27, 2008, 01:16:38 pm
bert
  • 423
Dammit!!!
« Reply #9 on: May 27, 2008, 01:16:38 pm »
hi,im using normal diesel at the moment,when im skint i use 75% new veg oil,still performs the same,my pump is standard apart from a rover 220 pin,2.5" one box system,standard new injectors and the pump is fairly new too,i run 11 psi so far and its quick enough for me  :twisted:
Bert
Reply #10May 27, 2008, 02:11:32 pm
Dammit!!!
« Reply #10 on: May 27, 2008, 02:11:32 pm »
Maybe that's my problem, maybe I should stop pushing 30+ psi  :twisted:
Reply #11May 27, 2008, 03:07:51 pm
blkboostedtruck
  • 1535
Dammit!!!
« Reply #11 on: May 27, 2008, 03:07:51 pm »
Dan i got some K26 around if you wanna experiment with?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #12May 28, 2008, 04:54:01 am
Justin
  • 455
Dammit!!!
« Reply #12 on: May 28, 2008, 04:54:01 am »
get me some of your specs and I might be able to hook you up with a new borg warner turbo charger. what kind of power you want to run, along with Nozzles, boost pressures, displacement and all that fun stuff.
later
jkeiffer
www.archeryprostaffmi.com
Reply #13May 28, 2008, 07:38:43 am
Dammit!!!
« Reply #13 on: May 28, 2008, 07:38:43 am »
Quote from: "blkboostedtruck"
Duane
Let me do some digging here Duane, I think Cody has one that needs rebuilt I think I can get that one and do a rebuild.
I will certainly get back to ya though.
Reply #14May 28, 2008, 07:44:58 am
Dammit!!!
« Reply #14 on: May 28, 2008, 07:44:58 am »
Quote from: "Justin"
later
jkeiffer
This could be fun,
I want to be as close to 150hp as I can get without loosing reliability. I would love 200 but I would like to keep the head under the hood.
Running a 1.6 ltr (1mm over), using Merc injectors @ 155bar and I have some Case injectors as well, those suka's flow some fuel for sure but I haven't been running them as it's hard to get a good idle.
I'm running a huge FMIC bar and plate style.
I would like to have it around 10psi @ 3000 RPM. Right now @ 3000 I'm running about 4-5 psi (freeway cruising) and about 750-800 on the EGT's I suspect that's largly due to the ACN trans, it's geared taller for freeway.
The only porting is gasket matching :(
What other info can I provide?
