S-PAutomotive.com
Author Topic: Finally got mileage figures for M-TDI in Land Rover  (Read 8355 times)
May 23, 2008, 10:04:58 am
« on: May 23, 2008, 10:04:58 am »
I finally had a mostly successful long trip under my belt, though when about 6 miles from, the IP started pouring out fuel, 1/4 tank in 6 miles.
Anyway, I checked mileage on 3 legs of my trip from Denver to Moab, and 150 miles of offroad during a 4 day camping trip. I figure those doing M-TDI conversions in their Suzuki's, Toyotas or whatever will know they can't get much worse mileage than this, with my 3500 lb brick. From Denver to Fruita I drove 221 miles, and got 30.8 mpg. Fruita to Moab, 90.4 miles, I got 32 mpg. 150 miles of all offroad plus about 62 back to Moab on highway I got 21.8 mpg. Low end torque seemed better than the IDI and I never felt at a loss for power.
Trip pics are here for those interested.
Reply #1May 23, 2008, 11:54:31 am
« Reply #1 on: May 23, 2008, 11:54:31 am »
I thought you were going to do some wheeling while you were there?
I don't see anything I would consider wheelin in those pics..   :lol:
Good report Jim. That mileage isn't anything to be ashamed of at all.
Reply #2May 23, 2008, 01:34:08 pm
« Reply #2 on: May 23, 2008, 01:34:08 pm »
I'm not ashamed of my mileage, just was trying to point out nothing could be less aerodynamic than my truck, so others mileage should be at least what mine is if not better. Guess I didn't word it quite right.
Most of the trucks were stock, so no super hard stuff, especially 150 miles of super hard stuff. The harder parts are actually mostly on video, but it's hard to take pics/vid while driving through stuff where you should have both hands on the wheel.. Looks like the nut? came off the shaft for the idle, allowing the o-ring to pop out.
Reply #3June 07, 2008, 04:06:35 pm
RabbitGTDguy
  • 1274
« Reply #3 on: June 07, 2008, 04:06:35 pm »
Jim...
Very nice...and not bad mpg at all for the brick. Ah...moab...need to get out there to do some mtb'n in the near future...
I keep trying to convince my brother to convert his 02 Wrangler to diesel...we'll see now as 31's and a 4 banger gasser on it just don't line up well. Though...he holds his own in the rock climbing!
Joe
1972 VW Westfalia
Reply #4June 14, 2008, 02:01:40 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #4 on: June 14, 2008, 02:01:40 pm »
Sorry to threadjack, but how much hassle was it to adapt to your Landy? Petrol (Gas!) $8.47/USgallon . 1958 series 2 Landrover. 20 mpg, if I am lucky. :roll:
Why am I curious! :twisted:
Reply #5June 14, 2008, 02:32:11 pm
« Reply #5 on: June 14, 2008, 02:32:11 pm »
Well, I had to design the adapter myself and have it made. Plumbing exhaust on the first version, AAZ with k-14, was a bit of a pain, though on the new turbo, the footwell had to be cut a little, and it is still tight. It was a fair bit of work, a ton more than you'd need for a 200TDI or 300TDI. All the work is here.
Reply #6June 14, 2008, 03:46:55 pm
« Reply #6 on: June 14, 2008, 03:46:55 pm »
hey jimfoo i've been looking into oil bath air filters recently and i thought of you when thinking back to the extreme wear in your engine.  not exactly performance, but it will remove virtually all dirt from the air.  especially useful for your offroad excursions  :D
Reply #7June 14, 2008, 03:49:42 pm
jackbombay
  • 599
Re: Finally got mileage figures for M-TDI in Land Rover
« Reply #7 on: June 14, 2008, 03:49:42 pm »
Quote from: "jimfoo"
  How fast were you cruising? And how many RPMs?
Reply #8June 15, 2008, 02:59:02 am
DonGTI
  • 172
« Reply #8 on: June 15, 2008, 02:59:02 am »
Quote from: "jtanguay"
Best oil bath oilfilters come off 1980's mercedeses... should be easily sourced
Fast and Cheap is not Reliable
Reliable and Cheap is not Fast
BUT
Reliable and Fast is NEVER Cheap...
                              - someone's wise words after my GTI engine died -
Reply #9June 15, 2008, 01:09:28 pm
« Reply #9 on: June 15, 2008, 01:09:28 pm »
Quote from: "jackbombay"
On the flat parts, around 65ish, 2800 rpm, slow following the stock vehicles up the passes, which were only on the first section, 30-35 mph.
Reply #10June 15, 2008, 01:12:10 pm
« Reply #10 on: June 15, 2008, 01:12:10 pm »
Quote from: "DonGTI"
I took an oilbath off. Thats part of the reason for the wear, the air hose had to climb the side of the battery and was eaten by the acid, allowing LOTS of dust in. Plus I worried about the oil should I roll. Don't need an easy route to a runaway engine.
Reply #11June 28, 2008, 08:13:00 am
smutts
  • 720
« Reply #11 on: June 28, 2008, 08:13:00 am »
Genius! Thankyou. 8)
Reply #12August 14, 2008, 11:30:37 am
arb
exhaust
« Reply #12 on: August 14, 2008, 11:30:37 am »
Say Jimfoo, did you do any painting of coating of the exhaust fitting you made for your turbo ? I am faborication mine now for my Diesel Caravan project and would not want to remake them in only a few years from Rust.
I bought some 1200 degree black paint I was thinking of using. I have 304 stainless steel for the manifold to turbo adaptor but the rest is steel.
Reply #13August 14, 2008, 12:05:25 pm
« Reply #13 on: August 14, 2008, 12:05:25 pm »
No I didn't. The flange is 1/4" though so shouldn't rust for a long time. The pipe is stainless for a ways, then aluminumized the rest of the way. Though it wouldn't hurt to paint it, I'm sure it gets beyond 1200 at times. Maybe you could get it ceramic coated?
Reply #14August 20, 2008, 12:55:11 pm
arb
« Reply #14 on: August 20, 2008, 12:55:11 pm »
I took back the 1200 degree paint to China-Mart and when to Meijer's and got some spray on 1200 - 2000 degree ceramic coating. The brackets holding my S.S. tubing are steel so they will rust quickely at that heat. This should help :-0
Fixmyvw.com
