Author Topic: Can ribbed tensioner be adjusted? (aaz)  (Read 2614 times)
May 04, 2008, 10:00:27 am
b1rdjx88
« on: May 04, 2008, 10:00:27 am »
Can the accessory belt tensioner on an aaz (non-AC) be adjusted?
I just installed a clutched TDI alternator pulley, and now it seems the tension is too high in the accessory belt, because the tensioner pulley is squealing.
The clutched pulley is a larger diameter than the old pulley. I think it may  actually be intended for the 120 amp alternator rather than my 90 amp one.
It fits the alternator shaft though, and it is not coming off now unless I buy the special tool. I understand it will change my tachometer readings, but I'm not too worried about that.  Is there anything I can do to relieve some tension from the tensioner?
Reply #1May 04, 2008, 10:26:34 am
« Reply #1 on: May 04, 2008, 10:26:34 am »
Get a longer belt at the local auto parts store. And if the tensioner is squealing, I'd replace it asap.
Reply #2May 04, 2008, 11:07:49 am
b1rdjx88
« Reply #2 on: May 04, 2008, 11:07:49 am »
wow. I guess I was trying to make things complicated.
You figure most auto parts places will have a range of sizes of this type of belt?  Sorry, I haven't checked before.
Reply #3May 04, 2008, 11:36:03 am
« Reply #3 on: May 04, 2008, 11:36:03 am »
Absolutely. I just measured about what I needed for my non-conventional alt install and they had it. The belts are standardized width wise, and come in tons of different lengths.
Reply #4May 05, 2008, 01:10:31 am
Torchd
  • 372
« Reply #4 on: May 05, 2008, 01:10:31 am »
Hey b1rdjx88!!
I wanna to the same pulley conversion in my car... can you please give me the part number if the pulley u used??  and if you can give me the diameter as well??
Really appreciate it thanx!!
Reply #5May 06, 2008, 11:36:53 pm
Torchd
  • 372
« Reply #5 on: May 06, 2008, 11:36:53 pm »
b1rdjx88!!
Can you please reply?
