Author Topic: Diesel Prices  (Read 9447 times)
Reply #15April 27, 2008, 01:23:53 pm
mdonau
  • 53
Diesel Prices
« Reply #15 on: April 27, 2008, 01:23:53 pm »
about 8,5$/gallon in Germany..
i have been driving on SVO and WVO some time now, SVO is not really critical, when it has good quality.
When driving on WVO i from time to times use biodiesel and gasoline to keep the pump clean and to avoid germs in the fuel system.
Audi 80 1,6TD:
http://rapsdb.rapsinfo.de/detail.php?id=1807
1,9l TD conversion done!
Reply #16April 27, 2008, 01:58:10 pm
burnt_servo
  • 278
Diesel Prices
« Reply #16 on: April 27, 2008, 01:58:10 pm »
it a 1.30 cdn here per litre right now , roughly 4.80 cdn  a american gallon , 5.80 cdn a imperial gallon .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #17April 27, 2008, 07:08:29 pm
vegfuel
  • 125
Diesel Prices
« Reply #17 on: April 27, 2008, 07:08:29 pm »
Another concern I have is the economy. I heard that you need to advance the timing and this could have an affect.
1986 Golf WVO converted.
Reply #18April 28, 2008, 12:15:10 am
Diesel Prices
« Reply #18 on: April 28, 2008, 12:15:10 am »
Quote from: "vegfuel"
the orifice of the nozzle in stock application isn't properly tuned to run on veg.  i would imagine replacing nozzles would be a better idea than messing with timing, although perfectly calibrating using one of those diesel pulse timing meter's while running on veg could be interesting!  i personally would like to see the difference while the system was running either fuels... i wonder if it would be that big?
Reply #19April 28, 2008, 12:33:49 am
vegfuel
  • 125
Diesel Prices
« Reply #19 on: April 28, 2008, 12:33:49 am »
Quote from: "jtanguay"
I'm just guessing it would. I can certainly hear the effects of B99 biodiesel when run in my Golf. The engine gets real quiet and seems to not get as hot. I'm wondering if getting some of those veg nozzles to make a bigger spray pattern if it would make a difference since veg oil has more mass.
Reply #20April 28, 2008, 09:57:54 am
burnt_servo
  • 278
Diesel Prices
« Reply #20 on: April 28, 2008, 09:57:54 am »
my experience has been , a bigger issue is getting the veg oil hot enough AT the injectors .
that means running a hotter thermostat , and a proper heat exchanger .
i've seen too many veg oil systems run too cool causing various problems .
the hotter the veg oil is ( using coolant as the heat source ) the closer it is to acting like diesel. meaning stock diesel settings , timing and nozels will work fairly well .
something i've run across with he cummins guys using a high lift cam plate and a 14mm pump head , they are running  into heat build up issues in the injection pump ( on diesel )  ...... i'm thinking this would be a ideal situation for veg oil , since the ip wouldn't be removing heat from the oil , but maybe even adding heat .
Reply #21April 29, 2008, 02:10:49 pm
smutts
  • 720
    ClackClackClackClackClack
Diesel Prices
« Reply #21 on: April 29, 2008, 02:10:49 pm »
$8.96 per US gallon. Mostly tax. This is why diesel tax fraud is a national sport over here.
With regards to SVO being too thick without heating, has anybody tried thinning it down with paraffin? Kerosene for those over the pond. :wink: . On its own it has terrible lubricity, but with an octane of zero, that should be a good cetane value. Say 20% paraffin to 80% veg oil. Any good disaster stories?   :D
THIS IS ONLY A QUESTION! DON'T DO THIS AT HOME!
Reply #22April 29, 2008, 02:32:46 pm
burnt_servo
  • 278
Diesel Prices
« Reply #22 on: April 29, 2008, 02:32:46 pm »
it's not so much that it's too thick , but more a matter of it needing to be at a higher temp as it's being injected into the engine to completely burn .....
otherwise you end up with the fuel your trying to burn running to the edges of the cylinder as it's burning , which then does damage to the rings and / or burns what engine oil is on the cylinder wall / in the top ring land
Reply #23April 29, 2008, 02:55:01 pm
vegfuel
  • 125
Diesel Prices
« Reply #23 on: April 29, 2008, 02:55:01 pm »
I hear 180*F or 82*C at least. Is there anyone on here with a kit from Greasecar.com? What the verdict on these?
Reply #24April 29, 2008, 04:55:50 pm
madmedix
  • 204
Diesel Prices
« Reply #24 on: April 29, 2008, 04:55:50 pm »
I've been lurking on the veg sites for awhile...the common denominator with veg conversion is HEAT. Hose-in-hose fuel systems (sheathed in insulation), in-tank heater, insulated tank, heated filter, heated lines to the IP and heated injector lines. It all adds up to big dough if you're not careful...but diesel isn't getting any cheaper either.
 The jury's out on Merc injectors (both sides swear success) but I've noticed the Merc folks seem to have less posts on driveability problems in the cooler temps.
Andy
'90 TD Jetta
Reply #25April 29, 2008, 05:28:21 pm
burnt_servo
  • 278
Diesel Prices
« Reply #25 on: April 29, 2008, 05:28:21 pm »
pricey .... yes .... and that is why i haven't done a proper install on my jetta sooner .
so far i have over 500.00 in just parts alone ( i'm expecting another 200.00 to 300.00 in other costs ) , and i'm building everything from scratch and using steel rather than aluminum for my tanks .
aluminum would add another 250-300.00 to the total cost .
right now at the current diesel prices , payback will be around 8 months to a year of regular driving .... sooner if i  do any sort of travelling for school or work .
Reply #26April 30, 2008, 12:07:04 am
dogday
  • 37
Diesel Prices
« Reply #26 on: April 30, 2008, 12:07:04 am »
Quote from: "smutts"
 :D  :D  :D  :D  :D
Amen to that.
Cool another local - I'm down on the coast south of Exeter...
Anyways short of a regular supply of red diesel (Not that I would advocate that of course  :wink: ) can I just add veg oil ( & any particualer veg oil?) from the store to my tank - say a approx 25% mix when I fill up - even that would save me approx £15 - £20 a tank... ($30 - $40)...
I have a 150k mile N/a mk3 glof ( and an AAZ in the garage for a rebuild  :wink: )
DD
I don't want a sig.
Reply #27April 30, 2008, 05:44:43 pm
madmedix
  • 204
Diesel Prices
« Reply #27 on: April 30, 2008, 05:44:43 pm »
I came across a site based in the UK awhile ago that advocated just that: cutting off the shelf veg oil with diesel. I think the suggestion was no more than 30% in the summer, 10 in the winter. Try a google search under vegetable oil + diesel + mix (or some such). Sorry, I didn't bookmark it.
Cheers,
Andy
'90 TD Jetta
Reply #28April 30, 2008, 10:53:22 pm
mantajohan
  • 19
Diesel Prices
« Reply #28 on: April 30, 2008, 10:53:22 pm »
Quote from: dogday
Quote from: smutts
 :D  :D  :D  :D  :D
Amen to that.
DD
canola oil or sunflower oil are among the best I think, soy oil is pretty good too from what ive heard
when it gets freezing only over the night and is close too or above freezing -3celsius when i start the car i have been blending 36-38% canola oil without any problems
in the summer I have been blending about 70% unused veggie oil
many people are running 50/50 without any problems(in the summer)
the limit to a good running engine is at about 85% veggie oil for vw, nissan kingcab and other swirl chambers (you can use 100% if you only heat the oil)
most mercedes can run on 100% veggie oil in the summer without any problem to start or run
in the winter I never blend, it gets down to -15celsius (5 Fahrenheit) sometimes more
doesn't work to blend at those temps, the vegoil blends are cloudy and plugs the fuel filter
in the great IDI engines with mechanical fuel pumps there is no need to blend only 25% the engines can handle a lot more without damage
however if the engine is bad already has bad compression or is worn out
vegoil use will make the engine give up a bit faster
TDI and other direct injection engines
some can handle as much as 25% vegoil some can't even handle that
and finally IDI with electrical injection pumps or lucas pumps
sometimes you look at vegoil and they are broken just like DI engines :roll:
BMW 525tds-94:  ?,?L/100km
blending veggie oil,
pros: easier starts, more power, longer lasting engine, smother running engine, less smoke
cons:not all eng/inj-pumps are suitable, have to endure hearing bull*** like: that it can't be done and that it damages the engine
Reply #29April 30, 2008, 11:08:59 pm
mantajohan
  • 19
Diesel Prices
« Reply #29 on: April 30, 2008, 11:08:59 pm »
--------------(boilingpoint) (viskositet 40c) (densitet) (flampunkt)
diesel ulsd _ 180-300C __ 1,9 cSt _____ 815kg/m3 _ >60C
diesel real__ 180-300C __ 4,2cSt ______ 845kg/m3 _ >60C
kerosene __ 150-300C __ 1,4cSt ______ 806kg/m3 _ >43C
this is my own research in my own country, many of us think that blending with ULSD is makes the engine run a bit better but it is is more expensive(many of us use the thick diesel oil)
the blend gets a bit thinner but the limit is still at about 85-86% vegoil on a swirlchamber engine
some tests say that blending 15% vegoil in parrafin gives back more lubricity than regular diesel has(can't confirm this)
well one time i spilled some vegoil on the ground lazy as I am i did't clean it up and "almost" slipped on it and sat on my behind :oops:
and another friend of mine tried to use 100% vegoil, the engine did´t start, we had to empty the fuel tank a bit and put in some diesel and empty out the fuel filter and put in diesel in it
after that it stated after a while...
