N/A to turbo questions
Topic: N/A to turbo questions (Read 7067 times)
April 24, 2008, 03:13:35 pm
vdubin_g60
April 24, 2008, 03:13:35 pm »
I have a 81 1.6 diesel rabbit. Going to turbo and have some questions.
First what turbos will fit on this manifold?
2Where does the egt go on this?
3what is this bracket?
4what are these threads for on the downpipe?
5What do i use for a gasket in there?
6what does this nipple do in the pic above?
7Is this intake gonna fit it looks small and doesn't have a hole for a bov like others have that i have seen
April 24, 2008, 03:55:08 pm
April 24, 2008, 03:55:08 pm »
1)K24, K14, T3, possibly more
2) Near where the turbo mounts, somewhere pre turbo that all the cylinders meet at
3)Holds the intake to the exhaust manifold (I think)
4) There is another bracket that goes there to hold the turbo to the manifold
5) Silicon?? Very little though
6) That goes to the injection pump LDA so you get more fuel under boost. Cap it off or run it to a boost gauge if you don't have a LDA
7) It looks like it will fit. I'm not sure what it is from
April 24, 2008, 04:01:29 pm
blkboostedtruck
April 24, 2008, 04:01:29 pm »
turn the yellow intake over and takea pic and post it! and same with your other intake so we can see the openings! can give better answer!
thanks Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
April 24, 2008, 04:39:03 pm
hamradio
April 24, 2008, 04:39:03 pm »
Alternatively, it wouldn't be much work to just make a gasket for that flange/elbow. Just get some gasket paper, cut appropriately, of if the edges are sharp enough, do the hammer on it to cut it thing.
If you don't want the spraypainted yellow manifold, I'd probably be interested in it if it's cheap.
April 24, 2008, 04:52:36 pm
truckinwagen
April 24, 2008, 04:52:36 pm »
yar, a manifold without the stupid diverter valve would be preferable in higher boost applications(and sweet on any motor)
and the bracket on the manifold bolts to the downpipe at the two threaded holes you asked about, makes the assembly a little more rigid.
83 Opel Kadett Diesel
April 24, 2008, 05:43:15 pm
vdubin_g60
April 24, 2008, 05:43:15 pm »
the yellow manifold and the silver one are the same. i took the yellow off. heres a pic of the holes.
im going to see if the holes match up with an old na intake mani
How much fuel do you need for a k24/t3. Ive been turning the fuel up but would i have to go into the pump timing? na pump
which is better/cheaper to find. what size t3 is the same as a k24.
Thanks for the help so far
April 24, 2008, 06:12:39 pm
blkboostedtruck
April 24, 2008, 06:12:39 pm »
thats a 1.9 intake "D" ports
Duane
'66 variant 1500S
April 24, 2008, 06:35:13 pm
vdubin_g60
April 24, 2008, 06:35:13 pm »
will it fit? on the 1.6
April 24, 2008, 06:41:59 pm
blkboostedtruck
April 24, 2008, 06:41:59 pm »
yep! pretty sure!
Duane
'66 variant 1500S
April 24, 2008, 07:22:21 pm
vdubin_g60
April 24, 2008, 07:22:21 pm »
i'll double check tomarrow
April 25, 2008, 02:19:32 pm
vdubin_g60
April 25, 2008, 02:19:32 pm »
also what can a guy use for the oil lines? tap on top of the oil filter and on the oil pan-anywhere?
where can i find a hose/elbow from the turbo to the intake manifold?
so all i need is a oil filter housing tapped, tap the oil pan. find a turbo
piping for an intercooler and an intercooler. oil lines. egt probe and gauge boost gauge anything im forgeting?
would i need a intercooler right away if i run low boost?
Reply #11
April 25, 2008, 03:51:52 pm
dillenger1
Reply #11 on:
April 25, 2008, 03:51:52 pm »
Get hose coupler from auto parts store ,they should sell you a 2"radiator hose for a truck.Ive got some and mates up perfect.The one i get has one 90 deg. elbow and is long enough to make enough couplers for a whole charge pipe system for your intercooler.Or theres feebay!
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #12
April 25, 2008, 11:59:27 pm
Torchd
Reply #12 on:
April 25, 2008, 11:59:27 pm »
Its a 1.9 TD manifold and yeha it will fit onto 1.6 no problem.... 1.9 manifolds were the ones that came without the BOV cut out.
Dont u wana add Turbo pistons and oil squirters??? its just sumdrilling and fixing!
Reply #13
April 26, 2008, 09:48:24 am
vdubin_g60
Reply #13 on:
April 26, 2008, 09:48:24 am »
I dont think that im gonna run a lot of boost and i already had the head off not too long ago for a fresh head gasket
Reply #14
April 26, 2008, 09:58:38 am
Reply #14 on:
April 26, 2008, 09:58:38 am »
it looks like someone did some porting on that intake. the inside is usually pretty rough and grainey.
the BOV is kinda useless if you ask me. the wastegate should be fine at regulating boost unless it gets stuck from not using it.
