Author Topic: Is gear on end of 1.6 I.S. same as 1.9 I.S.?  (Read 3332 times)
April 21, 2008, 10:34:47 pm
rabbid79
  • 684
« on: April 21, 2008, 10:34:47 pm »
Does anybody know if the little machined gear on the end of a 1.6 intermediate shaft is the same as the one on a 1.9 intermediate shaft?  The reason I ask, is because I'd like to use my old 1.5 vacuum pump on my 1.9.  Techtonics Tuning sells a distributor adapter ring for fitting the older 1.8 distributors into the holes of the newer 2.0 blocks, but they say that the gears are different, and you must either use your old 1.8 I.S., or put a bigger gear on your distributor in order to use the 2.0 I.S.  I'm wondering if I'm in pretty much the same boat with my 1.5 vacuum pump to 1.9 block conversion.  I'd like to use my 1.9 I.S., but may not be able to if the sizes are different.  Thanks.
'15 WRX
Reply #1April 22, 2008, 04:27:59 am
« Reply #1 on: April 22, 2008, 04:27:59 am »
the 1.9 IM pulley is smaller then the 1.6. I'm pretty sure the 1.5 and 1.6 are the same size.
Reply #2April 22, 2008, 07:19:22 am
« Reply #2 on: April 22, 2008, 07:19:22 am »
Pulley size shouldn't matter much if it's bigger, but if it's smaller, then your oil pump would turn slower, which still may not matter much depending on how much slower. I can measure my 1.9 pulley if you need me to.
Reply #3April 22, 2008, 08:34:59 am
« Reply #3 on: April 22, 2008, 08:34:59 am »
you won't be able to fit the timing belt on.
I just re-read your post. You are talking about the other end of the shaft aren't you?
Reply #4April 22, 2008, 03:26:53 pm
rabbid79
  • 684
« Reply #4 on: April 22, 2008, 03:26:53 pm »
Hi guys, thanks for the replies.  Yes, I'm talking about the little gear on the end of the shaft that mates to the gear on the vacuum pump.  I am trying to find out if they're compatible with each other.
'15 WRX
Reply #5April 22, 2008, 03:40:47 pm
blkboostedtruck
  • 1535
« Reply #5 on: April 22, 2008, 03:40:47 pm »
nope the 1.9 is different from a 1.6 and 1.5!
but i'm not sure if a 1.5/1.6 I.M. shaft would fit in a 1.9?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #6April 22, 2008, 05:16:47 pm
rabbid79
  • 684
« Reply #6 on: April 22, 2008, 05:16:47 pm »
That was my next question.  Hopefully a 1.5/1.6 shaft will fit.  Or can a 1.9 vacuum pump gear be adapted to a 1.5 pump?
'15 WRX
Reply #7April 22, 2008, 05:22:54 pm
« Reply #7 on: April 22, 2008, 05:22:54 pm »
Why do you want the 1.5 pump?
Reply #8April 22, 2008, 07:40:41 pm
rabbid79
  • 684
« Reply #8 on: April 22, 2008, 07:40:41 pm »
Because I have a pristine one already, and a remanufactured 1.9 pump is $180 from VW.  I also think they look cooler. :D
'15 WRX
Reply #9April 22, 2008, 07:43:50 pm
blkboostedtruck
  • 1535
« Reply #9 on: April 22, 2008, 07:43:50 pm »
Quote from: "rabbid79"
that might be a possibility? the vac. pumps look the same but the gears are different on the 1.9 thier bigger so they might come off? i have not looked at one close enough to see if it came off?
Duane
'66 variant 1500S
Reply #10April 22, 2008, 07:44:22 pm
« Reply #10 on: April 22, 2008, 07:44:22 pm »
Oh I see. Seems you already have the issue of the larger hole in the block for the pump covered...
I'm sure you could have the gear machined off and a 1.6 gear pressed onto the end of the shaft. Lots of custom work though $$$
Reply #11April 22, 2008, 08:58:08 pm
rabbid79
  • 684
« Reply #11 on: April 22, 2008, 08:58:08 pm »
It's starting to sound like a nightmare to adapt this thing.  Perhaps I ought to just pony up for a remanufactured unit.
'15 WRX
