Author Topic: diesel additive question  (Read 7147 times)
April 18, 2008, 12:15:36 pm
Diesel Cloud
  • 4
« on: April 18, 2008, 12:15:36 pm »
Are they really needed with the new low sulfur diesel on the market.?
My favorite air is black!!!
Reply #1April 18, 2008, 12:24:46 pm
« Reply #1 on: April 18, 2008, 12:24:46 pm »
I think so.
Reply #2April 18, 2008, 12:37:20 pm
1slowvw
« Reply #2 on: April 18, 2008, 12:37:20 pm »
If you are running an IDI without a rebuilt pump they are highly recomended from what I understand. It would seem that the new ULSD is really a very dry fuel and its very hard on the old seals in out pumps. I personaly have always run howes diesel additive in my car, but some old timers will swear by a bit of ATF or motorcycle injection oil, to keep the system well lubed.
1SlowVW
PS: If anyone cares to prove me wrong on any of this please feel free, like i said this is just how i understand it, and there are many people on this board who are more knowlegeble then myself (end disclaimer)
Reply #3April 29, 2008, 01:19:11 pm
Darth Garry
  • 136
    • http://www.notinteresting.com
« Reply #3 on: April 29, 2008, 01:19:11 pm »
I've been using Stanadyne Performance Forumla for about 5 years now.  Never had any issues with it.  It also revamps the lubricity for better pump and injector operation, and the seals, of course.
Garry
All for one, and one for Awesomeness!
Reply #4April 29, 2008, 02:25:03 pm
bevboyy
  • 200
« Reply #4 on: April 29, 2008, 02:25:03 pm »
I use 2 stroke oil as an additive - way cheaper than the regular diesel additives.
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #5April 29, 2008, 07:19:22 pm
« Reply #5 on: April 29, 2008, 07:19:22 pm »
Quote from: "bevboyy"
that may prolong old pump seal life too.
Reply #6April 30, 2008, 01:27:58 pm
Dirtrag2
  • 298
« Reply #6 on: April 30, 2008, 01:27:58 pm »
how much oil per tank?
I just use Amsoil Cetane boost for a bit more and cleaner power
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #7May 01, 2008, 10:00:30 am
burnt_servo
  • 278
« Reply #7 on: May 01, 2008, 10:00:30 am »
Quote from: "Dirtrag2"
i dump a litre of what ever is on sale at the time ( 2 stroke oil ) every couple tanks .
some times i'll dump some atf ( any brand / type will work i litre per tank  )  again what ever is cheapest .
this will also help clean the injectors  due to the high amounts of detergants in the oil .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #8May 01, 2008, 10:57:20 am
« Reply #8 on: May 01, 2008, 10:57:20 am »
Quote from: "burnt_servo"
i dump a liter of what ever is on sale at the time ( 2 stroke oil ) every couple tanks .
I wonder about the friction modifiers hurting the IP and injectors though...
In the ATF I mean..
Way back when we used ATF to fill up the fuel filter when we changed them out but at some point we stopped as we were told they had started adding these friction modifiers to aid the friction disks in the trans to grip better/last longer...
Reply #9May 02, 2008, 03:12:02 am
burnt_servo
  • 278
« Reply #9 on: May 02, 2008, 03:12:02 am »
Quote from: "zukgod1"
In the ATF I mean..
look at the rest of a trasmision that uses atf , in a automatic they have various types of oil  pumps and bearings under presure  .
many of the ford . mazda based manual transmisions use atf , as well as the transfer cases  .
in a limited slip diferential , the proper gear oil have a friction modifier .
any motorcycle with a "wet " style clutch has to have a friction modifier .
when i had my yz250 i used to run  ford type f all the time in the gear box , due to the fact it is a more " grabby " type of fluid compared to dextron 3  .
the friction modifier is desgined to work with the clutch lining  to allow it to grab the "steel " next to it .
any metal on metal contact  is properly lubricated
if your worried about it use something like dextron3 which is designed to "slip a bit "  for softer shifts , that say like a ford type f .
Reply #10May 06, 2008, 08:43:15 pm
Hermann
  • 9
« Reply #10 on: May 06, 2008, 08:43:15 pm »
My two cents - I added some ATF about three months ago to my 89 due to some leaking on the pump. (No time and too cold to work on). Seemed to work on the seals etc. - prolly need to o-hual the pump and all the seals. For what it is worth I think ULSD is and will have an effect on the older diesels out there - the actual symptoms will vary.
I cannot be sure what is best but I would suggest something as opposed to nothing - if only to make sure the ol' lube factor is there as well as keeping the seals at their best.
Then again I might just be crazy! :lol:
Failure to plan on your part does not constitute and emergency on mine.
_______________________________________
'89 Jetta (440k km and still gettin 53mpg!)
'99 Jetta TDI
'04 Golf  TDI (Wifey's car - Mom's Taxi)
