stock pump, how much boost with blocked wastegate?
Topic: stock pump, how much boost with blocked wastegate? (Read 1935 times)
April 16, 2008, 08:35:27 am
flapjack
April 16, 2008, 08:35:27 am »
1.6TD with a T3, 2.5" downpipe and stock 2" exhaust
With the wastegate blocked, should I be able to get more than 10psi with a completely stock pump?
Not sure if I should look for leaks/problems before I start to add fuel.
signature
April 16, 2008, 09:38:21 am
April 16, 2008, 09:38:21 am »
Any turbo should be able to make more than 10 PSI with a blocked waste gate, unless it's really big.
April 16, 2008, 02:07:53 pm
g-spec
April 16, 2008, 02:07:53 pm »
Im running a T3 on a 1.9TD with stock fueling and blocked wastegate and a modded boost pin....on a cool day I see about 20psi.....usually about 18psi.
My car still smokes like steam engine until it hits full boost, then its just a gray haze!!!!
April 16, 2008, 03:31:31 pm
April 16, 2008, 03:31:31 pm »
with my jetta on stock fueling i could only do 15psi, fueling is everything
April 16, 2008, 04:05:09 pm
oldskool rich
April 16, 2008, 04:05:09 pm »
its all down to fuel, ive done all the fuel mods and i shoot past 40psi
start with ur fuel screw, if still not enough get a bigger pump piston off a tdi
f6squared I.D.S.T
