Author Topic: Really rough when cold  (Read 3287 times)
April 07, 2008, 08:16:38 pm
kiff
  • 12
« on: April 07, 2008, 08:16:38 pm »
So I have been chasing down a cold starting problem for awhile now.  When I fire up the car it smokes like crazy, only running on 3 cycl (#2 is not firing) and runs super rough, after about 5-10mins, she smartens up, no smoke at all and runs on all 4.
I have replaced my glow plugs, still can't figure out what the issue might be.
Reply #1April 07, 2008, 08:34:49 pm
blkboostedtruck
  • 1535
« Reply #1 on: April 07, 2008, 08:34:49 pm »
time for compression test? or stickey injector or pump feed?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2April 07, 2008, 08:36:16 pm
truckinwagen
  • 1895
« Reply #2 on: April 07, 2008, 08:36:16 pm »
my car does the same thing, I have to put a heater under it in the winter to even get it to start at all.
even if everything checks out alright these motors can be a pain when cold.
83 Opel Kadett Diesel
Reply #3April 07, 2008, 08:53:29 pm
« Reply #3 on: April 07, 2008, 08:53:29 pm »
Two suggestions... in the order I'd do 'em in t'were it me:
-  swap #2 injector and another one, and see if the trouble follows the injector.
- check your compression with the engine stone cold, and then once it's warmed up
My personal experience, fwiw,  is that a diesel with good compression, good injectors, good timing, good glowplugs, nice synthetic oil, and a good battery will start at -30C without additional heaters the very first time you crank it.   If it's hard to start *something* is probably amiss.
Reply #4April 07, 2008, 09:02:52 pm
truckinwagen
  • 1895
« Reply #4 on: April 07, 2008, 09:02:52 pm »
that is true, however I have chased what is wrong so long and invested too much time and money and came up with nothing, so I am happy to stop worrying and put a heater under it
Reply #5April 07, 2008, 09:08:43 pm
kiff
  • 12
« Reply #5 on: April 07, 2008, 09:08:43 pm »
the car still starts just fine.  I Don't have a compression tester for a diesel, I may try moving the injectors around
Reply #6April 07, 2008, 10:35:40 pm
« Reply #6 on: April 07, 2008, 10:35:40 pm »
Quote from: "truckinwagen"
Yup... at a certain point you kinda hit diminishing returns on the detective work and go for what works, don't ya.
Reply #7May 21, 2008, 08:56:14 pm
turbosuzi
« Reply #7 on: May 21, 2008, 08:56:14 pm »
how do you know if a cyl is not firing on a diesel? I am having the same symptoms and was thinking that a cyl is not firing but I am not sure how to tell or why one would not fore.
Reply #8May 21, 2008, 08:57:47 pm
kiff
  • 12
« Reply #8 on: May 21, 2008, 08:57:47 pm »
Crack each injector, you should hear the idle drop.  Mine does not drop when cold, but does when warm.
