Author Topic: Put the 1.6TD pin in my AAZ today!  (Read 3985 times)
April 01, 2008, 10:37:47 am
James8485
  • 223
« on: April 01, 2008, 10:37:47 am »
wow what a difference!! its crazy!! and thats just with the stock turbo (little k03) i have the 1.6TD mani and k24 turbo all ready for it wow i cant wait just seeing that big improvmetn with the pin!! like before you could rev her up and nothing come out! now you rev her up and a nice black puff comes out! i know im gettting fuel now!! and i took it on highway couldnt see nowthing not even when i accelerate maybe only the guy behind me can see!!! :)  worth while mod for sure!! not doing nothing else other than bigger turbo as the cars great!!
a highly recommended mod for sure!!!!!!
thanks all for helping me with all the questions!!
---------James--------
Reply #1April 01, 2008, 11:44:32 am
saurkraut
  • 904
« Reply #1 on: April 01, 2008, 11:44:32 am »
With that much smoke, your probably generating some high EGTs.
Might want to back off till you have less smoke, until you can get a EGT measurement, pre turbo.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #2April 01, 2008, 12:32:34 pm
bert
  • 423
« Reply #2 on: April 01, 2008, 12:32:34 pm »
did the pin fit snug then? mine was loose in the bore,great when they are getting fuel  :twisted:
Bert
Reply #3April 01, 2008, 01:23:07 pm
James8485
  • 223
« Reply #3 on: April 01, 2008, 01:23:07 pm »
ya pretty snug, not like a press fit or anything but there didnt seem t be a hole lot of play....i used the spring and pin from 1.6 not just pin...
did you use both as well???  i am running just a smaller turbo right now are u as well or have you switch to T3 or K24
i am really happpy with the results though.....way better then before!   not to see what my gas milage will be!!! its so small and spools so fast even when im on higheway my gauge says like 8-9 PSI!! so i hope it doesnt keep dumping in fuel!!!!!
Reply #4April 01, 2008, 01:33:08 pm
DonGTI
  • 172
« Reply #4 on: April 01, 2008, 01:33:08 pm »
did you touch the fuel screw on the side of the pump or stock fuelling?
Fast and Cheap is not Reliable
Reliable and Cheap is not Fast
BUT
Reliable and Fast is NEVER Cheap...
                              - someone's wise words after my GTI engine died -
Reply #5April 01, 2008, 01:33:59 pm
James8485
  • 223
« Reply #5 on: April 01, 2008, 01:33:59 pm »
didnt touch the screw,,,,,,,stock fueling
Reply #6April 01, 2008, 01:36:15 pm
James8485
  • 223
« Reply #6 on: April 01, 2008, 01:36:15 pm »
with the first reply he said "with that much smoke" there isnt that much!!
like when i get on it driving i dont see any
but if im parked in drivway and give it a shot of gas i see a puff of black come out......nothign crazy but i can def tell there is more fuel going in when in boost
no problem!
Reply #7April 01, 2008, 09:23:57 pm
DonGTI
  • 172
« Reply #7 on: April 01, 2008, 09:23:57 pm »
Ok james... because over here they want us to leave the seal on the fuelling screw on so if it smokes to much i wouldn't be able to adjust it back down again and fail MOT/VRT...
BUT
Reply #8April 02, 2008, 06:09:39 am
saurkraut
  • 904
Re: Put the 1.6TD pin in my AAZ today!
« Reply #8 on: April 02, 2008, 06:09:39 am »
Quote from: "James8485"
Oops, re-read your post.  When you wrote "couldnt see nowthing" I interprited as a huge cloud of black smoke.  If you not seeing smoke while driving, you probably O.K.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #9April 02, 2008, 07:18:50 am
James8485
  • 223
« Reply #9 on: April 02, 2008, 07:18:50 am »
haha np prob i should have been al;ittle more descriptive!!
its not to bad now i did turn it down and it just sucks as i still have the stock turbo on so i drive on highway and im in boost wel RPM 3000
boost 10PSI so i wonder how this will affect my milage!
Reply #10April 02, 2008, 02:15:18 pm
numbnuts
  • 99
« Reply #10 on: April 02, 2008, 02:15:18 pm »
Sounds cool, i think i am going for the rover pin as recommended by bert 8)
Reply #11April 02, 2008, 03:27:25 pm
g-spec
  • 289
« Reply #11 on: April 02, 2008, 03:27:25 pm »
I just modified my 1.9TD boost pin....took it to a grinder and then polished it. I took it down to maybe a 45 degree angle and almost half way into the pin itself, and there is a difference....especially after about 2.5K rpms....it actually pulls stronger in those rpms then anywhere else!!!! I have a second pin that I plan on getting a even more aggresive cut!!!!
Reply #12April 02, 2008, 03:37:29 pm
James8485
  • 223
« Reply #12 on: April 02, 2008, 03:37:29 pm »
wouldnt your fuel shut off pretty close to that???i notice mine pulls better in lower RPM but i do have the quick spoolin turbo so maybe thats it after 2500 it just revs dont really feel much power so hoping once i get that other turbo on she will pull nice and hard!!
Reply #13April 02, 2008, 03:42:00 pm
g-spec
  • 289
« Reply #13 on: April 02, 2008, 03:42:00 pm »
I have a T3 turbo on my car with a blocked wastegate! Its running about 18psi. Takes a while for it to spool especially with the stock exhaust.....I plan on making a free flowing one this summer.
as for power there is about nothing from 1000 to 2000 then it slowely starts making power and at 2500 it really takes off!!!
I have the fuel screw turned in about 1/4 of a turn....if that!!!
Reply #14April 02, 2008, 04:01:03 pm
James8485
  • 223
« Reply #14 on: April 02, 2008, 04:01:03 pm »
did ya have to turn your idle down or leave it idle higher
whats your idle at>
