Author Topic: Just blown my turbo!  (Read 4355 times)
March 27, 2008, 11:43:18 am
MontanaGTD
  • 230
    • http://www.dub-style.com
« on: March 27, 2008, 11:43:18 am »
Was working under my car today on the ramp (4 poster) to find out why my handling sucked (its a knackered ball joint!) and I got dripped on! looked up to find a huge patch of oil on the bulk head - lowered the car back down and pulled off my intercooler pipes - to find the main pipe to the intercooler soaked in oil!
Did think that it was a Garrett on it - now i'm not so sure! Where is best to get either my unit rebuilt - or what fits straight onto my engine as an upgrade?? (1991 SB engine code - mk2 golf)
MK3 Polo G40 - Sold
MK2 Golf GTD in Montana Green - FORSALE
MK2 Scirocco Scala 1.8i - FORSALE
MK4 Polo 6n 16v 5dr with A/C - othercar/wifes learner
Skoda Fabia VRS - new Daily
Reply #1March 27, 2008, 12:07:09 pm
aidan
« Reply #1 on: March 27, 2008, 12:07:09 pm »
My J reg GTD with SB engine had a k14 on it.
I was tempted to put a gt15 off a mk3 golf on mine, but the downpipe would cause issues with the gear linkage, so a straightforward swap would be any 1.6/1.9td turbo as far as i know
Reply #2March 27, 2008, 12:54:59 pm
MontanaGTD
  • 230
« Reply #2 on: March 27, 2008, 12:54:59 pm »
Really?
What should i do then? clean out the pipes and put a new crank breather unit in?
MK3 Polo G40 - Sold
Reply #3March 27, 2008, 01:02:17 pm
« Reply #3 on: March 27, 2008, 01:02:17 pm »
I've seen that some people put a gasser breather on which goes where the oil cap is. That way they have 2 breathers and can handle more flow with less oil.
Reply #4March 27, 2008, 01:29:27 pm
MontanaGTD
  • 230
« Reply #4 on: March 27, 2008, 01:29:27 pm »
Where is the breather unit - Please??? I hope it aint the turbo - i've just saved up £700 to get my rear panel repaired (rust) - wasnt looking forward to spending that on a new turbo!
MK3 Polo G40 - Sold
Reply #5March 27, 2008, 01:30:31 pm
MontanaGTD
  • 230
« Reply #5 on: March 27, 2008, 01:30:31 pm »
Is there an easy way to test if its the turbo? Remove the boost pip end from the turbo to the intercooler - put a white sheet on the end of it and rev the engine?
MK3 Polo G40 - Sold
Reply #6March 27, 2008, 01:43:05 pm
« Reply #6 on: March 27, 2008, 01:43:05 pm »
Quote from: "MontanaGTD"
I don't have a great picture, but the breather comes off the engine on the far right of the valve cover. You may or may not have the black tube that also connects to it. From there it goes to the line between your air filter and turbo. There is also a baffle which you can put under the valve cover if you don't have one, which helps block oil from going out the vent. The gasser vent screws on where the oil cap is, then the cap screws on top of it.
If the engine is running and you remove the oil cap, how much air do you feel coming out? If a lot, then the vent is probably the problem. If not much, then it could be the turbo.
Reply #7March 27, 2008, 02:16:42 pm
rallydiesel
  • 1880
« Reply #7 on: March 27, 2008, 02:16:42 pm »
Well, you could try disconnecting the vent hose, block off the hole on the intake hose and attach a longer length of hose to the vent hose and run it under the car. Then clean the intercooler pipe of oil and see if you get more oil in it after driving a bit.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #8March 27, 2008, 02:36:46 pm
MontanaGTD
  • 230
« Reply #8 on: March 27, 2008, 02:36:46 pm »
Quote from: "jimfoo"
Where can i get the baffle from?
MK3 Polo G40 - Sold
Reply #9March 27, 2008, 03:18:58 pm
« Reply #9 on: March 27, 2008, 03:18:58 pm »
Most any gasser at a junkyard I believe.
Reply #10March 27, 2008, 03:39:51 pm
MontanaGTD
  • 230
« Reply #10 on: March 27, 2008, 03:39:51 pm »
Sweet!
MK3 Polo G40 - Sold
Reply #11March 28, 2008, 01:17:21 am
MontanaGTD
  • 230
« Reply #11 on: March 28, 2008, 01:17:21 am »
Going to take the pipe off the vent - bung the one on the inlet pipe and route a hose from the breather into a plastic coke bottle. The i'll clean out the boost pipes, then take it for a run and see what happens - oil in the catch tank = breather. Oil back in the boost pipes = turbo!
Does that make sunse?
MK3 Polo G40 - Sold
Reply #12March 28, 2008, 11:33:14 am
MontanaGTD
  • 230
« Reply #12 on: March 28, 2008, 11:33:14 am »
No oil from the turbo! :) split the breather pod and it was choked! So its getting soaked in Redex overnight and then put back together!
MK3 Polo G40 - Sold
