Author Topic: 90 to 100 axle swap  (Read 11016 times)
March 19, 2008, 04:54:38 am
stewardc
90 to 100 axle swap
« on: March 19, 2008, 04:54:38 am »
My 90mm inner axle stubs are ridged and hard to seal, so I think I'll swap to newer 100mm axles. From what I understand, I need inner axle stub, spindles, carriers and axles from a 16V Scirocco. Is that all I need?
Reply #1March 19, 2008, 07:03:45 am
90 to 100 axle swap
« Reply #1 on: March 19, 2008, 07:03:45 am »
Sounds like you got it covered.  The only unknown is weather or not you will need spindles and carriers.  I have yet to find any definitive evidence that the outer splines on a 100mm axle are different from a 90mm axle.  I'd like to know that, though, when I do my TDI swap, I plan on using 16v Scirocco axles to mate with the 02J tranny flanges, but I have no idea what to do on the wheel side.  :P
Reply #2March 19, 2008, 07:23:22 am
90 to 100 axle swap
« Reply #2 on: March 19, 2008, 07:23:22 am »
can't you just keep the 90mm axle shafts on the outer?
Reply #3March 19, 2008, 08:25:32 am
90 to 100 axle swap
« Reply #3 on: March 19, 2008, 08:25:32 am »
I didnt think the outer part was any differant..?
I swaped over some mk3 knuckles on my mk2 and the outer is the same.
I pressed in new bearings but reused the splined part fropm the mk3, was under the impression all mk3's had the 100mm axles.
Anywho, I know have 11" rotors and dual piston Audi calipers with mk3 knuckles on my mk2
Before
AFTER
Reply #4March 19, 2008, 09:46:14 am
rallydiesel
  • 1880
90 to 100 axle swap
« Reply #4 on: March 19, 2008, 09:46:14 am »
Just a small improvement there  :o .
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #5March 20, 2008, 08:20:34 am
90 to 100 axle swap
« Reply #5 on: March 20, 2008, 08:20:34 am »
I'm hoping the Mk3 knuckles will work on the Mk1's as well.  ;)  (that's my plan anyway)
Reply #6March 20, 2008, 02:12:58 pm
Op-Ivy
  • 513
90 to 100 axle swap
« Reply #6 on: March 20, 2008, 02:12:58 pm »
Quote from: "zukgod1"
AFTER
Beauty!
Reply #7March 20, 2008, 07:34:41 pm
hillfolk'r
  • 1532
90 to 100 axle swap
« Reply #7 on: March 20, 2008, 07:34:41 pm »
ok speaking of 90mm vs. 100
i wanna lower my front on my rabbit,and im runnin a 80% peloquin
in order to lower it,im told to convert to 100mm cv's
cant i just swap the inner joints+the trans. flanges to 100mm,and use my"old" driveshafts and orig outer joint???
Throttle cables ftw
Reply #8March 21, 2008, 03:01:31 am
stewardc
90 to 100 axle swap
« Reply #8 on: March 21, 2008, 03:01:31 am »
Sorry, folks, but this thread is for Mk 1 only.
Reply #9March 21, 2008, 11:33:57 am
90 to 100 axle swap
« Reply #9 on: March 21, 2008, 11:33:57 am »
Quote from: "hillfolk'r"
Yup, I think so.
Reply #10March 21, 2008, 12:02:35 pm
stewardc
90 to 100 axle swap
« Reply #10 on: March 21, 2008, 12:02:35 pm »
I thought so too,  but was told the 100mm inner flanges have a different offset than the 90mm ones. Is this really true???
Reply #11March 21, 2008, 12:03:07 pm
stewardc
90 to 100 axle swap
« Reply #11 on: March 21, 2008, 12:03:07 pm »
repost
Reply #12March 21, 2008, 01:50:50 pm
90 to 100 axle swap
« Reply #12 on: March 21, 2008, 01:50:50 pm »
What do you mean by offset?
I suppose if you had 2 axles one 90mm and one 100mm you could compair if no one knows for sure.
Reply #13March 21, 2008, 02:51:05 pm
stewardc
90 to 100 axle swap
« Reply #13 on: March 21, 2008, 02:51:05 pm »
It wasn't the axle itself, but the transmission flange. When we put the 100mm flange on, the 90mm axle was too long.
Reply #14April 07, 2008, 03:52:43 am
stewardc
90 to 100 axle swap
« Reply #14 on: April 07, 2008, 03:52:43 am »
Any authoritative responses? I need help here.
