Author Topic: 90 to 100 axle swap  (Read 11300 times)
Reply #15April 07, 2008, 04:40:07 am
90 to 100 axle swap
« Reply #15 on: April 07, 2008, 04:40:07 am »
the 100mm axles i bought fit into my mk2 spindles.  only problem is that they are about 2 inches too long...
Reply #16April 07, 2008, 08:09:40 am
90 to 100 axle swap
« Reply #16 on: April 07, 2008, 08:09:40 am »
I dont have a 100mm flange to compair but if they are the same axles the flange can't be different depths.
There isn't enough slip on the axle to allow for much difference either way.
Reply #17April 07, 2008, 08:12:02 am
90 to 100 axle swap
« Reply #17 on: April 07, 2008, 08:12:02 am »
Quote from: "jtanguay"
2"? Holly mackerel!!
That should be very obvious on the flange..
Swap the new end that bolts to the trans to your old axles. ?
Reply #18April 13, 2008, 04:25:53 am
stewardc
90 to 100 axle swap
« Reply #18 on: April 13, 2008, 04:25:53 am »
I THINK the cure is 16v Scirocco axles.
Reply #19April 13, 2008, 04:13:21 pm
90 to 100 axle swap
« Reply #19 on: April 13, 2008, 04:13:21 pm »
Quote from: "zukgod1"
instead i swapped 90mm tranny flange on the tranny... problem solved  :lol:
Reply #20August 04, 2009, 05:46:27 am
Hiho
  • 77
Re: 90 to 100 axle swap
« Reply #20 on: August 04, 2009, 05:46:27 am »
the 100mm inner cv joints from A3 series will fit the splines of an A1 drive shaft however, the 100mm inner cv joint is thicker than the 90mm inner cv joint so to make it fit the difference in thickness needs to be machined off the shoulder on the drive shaft. Otherwise the cv joint cant slide far enough along the splines to fit the circlip
1978 1.5 GLD
1978 1.6D soon to be TD
Reply #21August 16, 2009, 07:32:38 am
somolovitch3
  • 290
« Reply #21 on: August 16, 2009, 07:32:38 am »
Acually I was thinking of going the other way, 90 mm trans flanges instead of 100 mm's. Its not like the dumb bunny has a whole lot of guts or anything. :P
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #22September 12, 2009, 09:03:13 am
« Reply #22 on: September 12, 2009, 09:03:13 am »
im running 90mm axles in my rabbit. i took the rabbit axles, took the inner cv's off, put some 100mm CV's on my axles and called it good. the only reason my axles are a tight fit is because they are axles from a 4 speed car, and the 4 speed trans is narrower in the final drive section, by almost a whole inch. i have to have my engine loose in the mounts to put the axles in. or have the ball joints pulled and swing the hub and strut out of the way.
