Wouldn't it be possible to build a small processor to control a VNT on a mTDI? All it needs is inputs for rpm, boost pressure, possibly elevation and 1 or 2 other variables. Then the output for a n75. Does it exist alreadyand i don't know?
Apparently I did read far enough! That does look fairly simple. Now, to find it stateside here! Joe
Quote from: "RabbitGTDguy"Apparently I did read far enough! That does look fairly simple. Now, to find it stateside here! JoeI am going to build two of them next month. One for a friend (VNT15 on a 1.6TD) and one for my Cummins 5.9. I will be adding a TPS, so that will take a bit of experimenting.
Keep in mind that the megasquirt boost control is made to work with a TPS and is tunable via a 6x6 table in the software. See these links...http://www.e30tech.com/forum/showthread.php?s=7fe1ebeb867cf743c6684a264d796b20&t=30543http://forums.turbobricks.com/showthread.php?t=80599PS. This will allow you to set any boost level at any rpm and throttle angle which woudl allow you to run a big turbo without surging the compressor
