Author Topic: Is this crank forged or cast?  (Read 3241 times)
March 13, 2008, 09:45:47 pm
rabbid79
  • 684
« on: March 13, 2008, 09:45:47 pm »
Hi, I've got one of those new 1.9s from Vanamania.  I'm trying to tell if the 95.5 mm crank that it has is forged or cast.  I've read on Vortex that one way to tell is to look at the width of the seams.  They said if they're very thin, then it's cast, but if they're wider than 1/8" then it's forged.  As you can tell, the seams on this crank are at least 1/4" inch wide.  I'm 99.9% sure it's the same crank that is in the 1Z/AHU.  It is part number 028 105 263 D.  The engine was supposedly built in 2004.  Does anybody have any ideas?
'15 WRX
Reply #1March 14, 2008, 04:19:34 pm
itzdshtz
  • 94
« Reply #1 on: March 14, 2008, 04:19:34 pm »
I am sure that this crank is a forged unit.
      Herman
1989 Vanagon Westfalia 2.1
1987 Vanagon Syncro Westfalia 2.0 TD
2004 Audi allroad 4.2
1997 Audi A6
1985 Audi 5000 Td
http://vanagonsyncroproject-herman.blogspot.com/
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02
Reply #2March 14, 2008, 08:20:36 pm
rabbid79
  • 684
« Reply #2 on: March 14, 2008, 08:20:36 pm »
Hi, is that because of the way the seams look, or some other knowledge specific to this crankshaft?
'15 WRX
Reply #3March 14, 2008, 09:35:19 pm
itzdshtz
  • 94
« Reply #3 on: March 14, 2008, 09:35:19 pm »
Hi, yes it is the way the seam is, like they said, a cast crank has a very narrow seam where the two half of the mold fit together, another give away is that with a cast crank, the surface looks more like the inside of your block casting. You can see the grains of the casting sand in it.
If you would clean the crank around the # 4 conrod you would see a blue color from the heat treating process  that is only used on steel crankshafts.
   Herman
1997 Audi A6
1985 Audi 5000 Td
Reply #4March 14, 2008, 10:36:31 pm
rabbid79
  • 684
« Reply #4 on: March 14, 2008, 10:36:31 pm »
Cool!  Thanks for the reply.  I'll have to go out and look for those things.
'15 WRX
