Author Topic: I need some bolts!  (Read 4830 times)
March 08, 2008, 06:23:03 am
jerome
  • 4
I need some bolts!
« on: March 08, 2008, 06:23:03 am »
Hello.
I need the four 12 pt bolts that mount the turbo to the exhaust manifold for a 92 jetta turbo diesel. If anybody has any spares or knows where to source some, I'd appreciate if you contacted me. Thanks.
Reply #1March 08, 2008, 06:32:37 am
I need some bolts!
« Reply #1 on: March 08, 2008, 06:32:37 am »
If nothing else, I'd bet your local dealer could get them.
Reply #2April 09, 2008, 07:38:13 am
Turbinepowered
  • 1206
I need some bolts!
« Reply #2 on: April 09, 2008, 07:38:13 am »
I found some in grade 14.9 metric at ACE. Contractor supply houses would probably have them, too.
Reply #3April 09, 2008, 09:30:33 am
I need some bolts!
« Reply #3 on: April 09, 2008, 09:30:33 am »
Quote from: "Turbinepowered"
go this route.  dealers cost too much!
Reply #4April 09, 2008, 11:01:39 am
I need some bolts!
« Reply #4 on: April 09, 2008, 11:01:39 am »
Ya, I used some grade 8 bolts from the hardware store.
Holding just fine.
Reply #5April 09, 2008, 11:23:12 am
Turbinepowered
  • 1206
I need some bolts!
« Reply #5 on: April 09, 2008, 11:23:12 am »
Quote from: "jtanguay"
I think I paid sixty cents apiece for them, identical bolts but a higher grade than the ones I took off.
Reply #6April 11, 2008, 06:54:52 pm
aranay
I need some bolts!
« Reply #6 on: April 11, 2008, 06:54:52 pm »
Be carefull changing the bolt grade on things that have a lot of vibration and heat.  a higher grade doesnt always mean better- just harder. for example a grade 5 bolt is a slightly softer steel than a grade 8 bolt but it has more flex whereas a grade 8 bolt would be more likely to crack than the grade 5 bolt (providing the torque values are correct)
Reply #7April 15, 2008, 07:26:27 am
Turbinepowered
  • 1206
I need some bolts!
« Reply #7 on: April 15, 2008, 07:26:27 am »
Quote from: "aranay"
True enough, but the bolts I've been getting are 10.9 metric, which was present in the stock bolt selection on the block. 8.8s and 10.9s are both being replaced with new 10.9 grade bolts. I don't think any harm's going to come from the replacement, personally.
I might have a problem down the road, the socket head bolts are all 12.9 metric grade, which was all I could find. Stock's only 8.8 metric.
Reply #8April 15, 2008, 07:40:55 pm
aranay
I need some bolts!
« Reply #8 on: April 15, 2008, 07:40:55 pm »
good enough then. I'd say youre likely ok.  i know a lot of people that have this thinking that bigger is better with no consideration for the engineering theory behind the madness.
