Author Topic: Suzuki Samurai TDI Engine Swap  (Read 11105 times)
March 07, 2008, 06:34:52 am
jeff211
  • 15
« on: March 07, 2008, 06:34:52 am »
I have a 98' TDI Jetta motor I want to put in my 86'
Suzuki Samurai.Can the injector pump be changed to avoid using the computer?
Reply #1March 07, 2008, 07:11:56 am
« Reply #1 on: March 07, 2008, 07:11:56 am »
Do a search for m-tdi. You can modify a mechanical pump to work on a TDI, so that all you have is a wire to the fuel cutoff solenoid. No electronics at all.
Reply #2March 07, 2008, 05:30:19 pm
jeff211
  • 15
« Reply #2 on: March 07, 2008, 05:30:19 pm »
does anyone know where I can send my pump to be turned into a M-TDI?
Reply #3March 07, 2008, 05:36:10 pm
« Reply #3 on: March 07, 2008, 05:36:10 pm »
Giles can do it, and do a mighty fine job as well. http://vwdiesel.net/phpBB/viewtopic.php?t=3100
Reply #4March 07, 2008, 08:11:00 pm
hillfolk'r
  • 1532
Re: Suzuki Samurai TDI Engine Swap
« Reply #4 on: March 07, 2008, 08:11:00 pm »
Quote from: "jeff211"
yes,yes,and yes! do the swap:)
im sent :wink:
i saw them doin a 1.9 td  swap(i think it was an idi)on that show extreme 4x4....they were sayin power was good with that. ...
i was imaginin  a m tdi thats even "mild" would be way better
want a rock crawler thatll probably run low 15's/maybe hi 14s i dunno ??
build it :twisted:  :twisted:
Throttle cables ftw
Reply #5April 16, 2008, 12:19:15 am
samurai guy
  • 1
« Reply #5 on: April 16, 2008, 12:19:15 am »
I was searching on this swap for myself and stumbled on this thread. So you can have a VW TD work on one wire and have the pump changed? I dont really know much about diesels but from what I have read this swap sounds promising. :P
Reply #6April 16, 2008, 04:50:19 am
« Reply #6 on: April 16, 2008, 04:50:19 am »
Quote from: "samurai guy"
yep Giles can do a sick mTDI pump for you.  lots of potential!  upgrade to some .216 injector nozzles for craaazy power  :twisted:
Reply #7April 16, 2008, 06:35:48 am
« Reply #7 on: April 16, 2008, 06:35:48 am »
You don't need to change the pump unless you are using a TDI engine that normally has lots of electronics. The older IDI engines already only need 1 wire. On this list, a "TD" is an IDI, and you will get different answers than what you might need if you confuse the two.
