Author Topic: Were all AAZ's TD?  (Read 3023 times)
March 04, 2008, 09:14:17 pm
Powered by Spearco
  • 1203
Were all AAZ's TD?
« on: March 04, 2008, 09:14:17 pm »
I found a suplier for new OEM German AAZ cylinder heads, fully loaded, cam to valves for $400 plus shipping. They do not disclose wheather it's DT or NA. So is there a difference, if so, is it the ex. valves. :?:
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #1March 04, 2008, 10:02:48 pm
Powered by Spearco
  • 1203
Were all AAZ's TD?
« Reply #1 on: March 04, 2008, 10:02:48 pm »
Come one I see that you all are looking at this and are just ignoring it.
Please, any thing will help. :oops:
'13 Golf R:. Tuned
'98 Puch G320
Reply #2March 04, 2008, 10:14:10 pm
Powered by Spearco
  • 1203
Were all AAZ's TD?
« Reply #2 on: March 04, 2008, 10:14:10 pm »
Thank you libbybapa for your reply. Do you think that $400 is a good deal for a complete cylinder head. It's for my 1.6TD Scirocco drag project.
'13 Golf R:. Tuned
'98 Puch G320
Reply #3March 05, 2008, 12:22:25 am
janb
  • 167
Were all AAZ's TD?
« Reply #3 on: March 05, 2008, 12:22:25 am »
have you checked with
http://www.aluminumheads.com/  (PDX)
they've done all my TD's
If I'm not mistaken, I think you are safe once you get into the HYD heads, as I think they are all TD compatible.  I have some HYD 1.6 configuration heads on my AAZ's. They were long blocks and currently N/A, but have 'squirters' so will be TD when I move to higher altitude.
The Stealth Rabbit
VW-d's are forever
Reply #4March 05, 2008, 07:47:17 am
subsonic
  • 1836
Were all AAZ's TD?
« Reply #4 on: March 05, 2008, 07:47:17 am »
Quote from: "Powered by Spearco"
That does sound cheap.  You may want to find out who the maker is if possible.  From what I have read here, quality does differ quite a bit.
Reply #5March 05, 2008, 06:19:18 pm
Were all AAZ's TD?
« Reply #5 on: March 05, 2008, 06:19:18 pm »
400, holy crap thats a steal
Reply #6March 09, 2008, 08:54:52 pm
Powered by Spearco
  • 1203
Were all AAZ's TD?
« Reply #6 on: March 09, 2008, 08:54:52 pm »
I called the supplier and they are OEM parts. New not rebuilt. I'll be buying one as soon as I get the bottom end checked out by the mechine shop. It's a 1.6 TD bottom end, so one of the coolant passages will need to be pluged or welded to make the 1.9 head fit. Same for the 1.9 head oil passage, it will need to be welded or pluged. I'll take pics of the head when it arrives.
'13 Golf R:. Tuned
'98 Puch G320
Reply #7March 10, 2008, 07:25:10 am
Were all AAZ's TD?
« Reply #7 on: March 10, 2008, 07:25:10 am »
Are you using a solid lifter block?
Reply #8March 11, 2008, 08:24:45 pm
Powered by Spearco
  • 1203
Were all AAZ's TD?
« Reply #8 on: March 11, 2008, 08:24:45 pm »
Yes, I will be using a solid lifter block from a '85 TD Jetta.
'13 Golf R:. Tuned
'98 Puch G320
