Author Topic: Mounting a VNT to an AAZ. Does this oil return look right?  (Read 4079 times)
February 20, 2008, 06:56:35 pm
rabbid79
  • 684
« on: February 20, 2008, 06:56:35 pm »
Hi, I'm mounting a VNT-17 to an AAZ.  I have a spare VNT-15 that I mounted to the AAZ to test the fitment of the oil return line it came with.  Does anybody know if this is how the oil return on a TDI looks, or is it further down on a TDI block?  It doesn't look like it would get very good drainage if I used this particular oil return line.  Does anybody know of one that would for sure work better?  Thanks.
'15 WRX
Reply #1February 22, 2008, 08:21:45 am
« Reply #1 on: February 22, 2008, 08:21:45 am »
make a new line.  the oil might not drain properly with that 'snake' line.
does anyone know where to get the exhaust flange for VNT15/17 ?  from there i could get my downpipe made up...
thanks
Reply #2February 22, 2008, 09:07:49 am
« Reply #2 on: February 22, 2008, 09:07:49 am »
Quote from: "jtanguay"
thanks
I made mine out of some 3/8" steel. Just need to drill 3 bolt holes and use a hole saw for the larger hole.
Reply #3February 22, 2008, 02:45:44 pm
andy2
« Reply #3 on: February 22, 2008, 02:45:44 pm »
I'm pretty sure thats what It should look like.On my ALH with vnt15 it looks like that.
Reply #4February 22, 2008, 08:21:22 pm
rabbid79
  • 684
« Reply #4 on: February 22, 2008, 08:21:22 pm »
Really?  So the hole doesn't look too high up on the block?  It just looked a little shallow to me.  I wasn't sure if the hole was positioned differently on the AAZ vs. the ALH blocks.
'15 WRX
Reply #5February 23, 2008, 02:10:52 am
« Reply #5 on: February 23, 2008, 02:10:52 am »
Quote from: "jimfoo"
thanks
hmm good idea thanks!  that is where the oil drain on my 1Z block is.
Reply #6February 23, 2008, 05:59:59 am
andy2
« Reply #6 on: February 23, 2008, 05:59:59 am »
If you position the line over the hole you'll probably find that it wants to sit there.It looks poor but will work.It you could find a pic of the alh that would confirm this.
Reply #7February 23, 2008, 06:03:47 am
Tintin
  • 1279
« Reply #7 on: February 23, 2008, 06:03:47 am »
AAZ, 1Z/AHU, ALH,  the oil return hole for the turbo on the block is positioned at the same place, idem for PD motor.
Reply #8February 23, 2008, 08:36:46 am
rabbid79
  • 684
« Reply #8 on: February 23, 2008, 08:36:46 am »
Ok, thanks guys.
'15 WRX
Reply #9February 23, 2008, 12:36:25 pm
boxer246
  • 109
Turbo
« Reply #9 on: February 23, 2008, 12:36:25 pm »
Looks right to me, my AHU is the same.  As long as its going downhill, your good to go.
Ash
'81 VW Caddy 1.6 now a TD
'88 Vanagon (building a AHU M-TDI)
