1.6td swap into b3 wagon?
Topic: 1.6td swap into b3 wagon? (Read 4273 times)
February 20, 2008, 01:44:58 pm
hamradio
February 20, 2008, 01:44:58 pm »
I'm pretty sure I remember reading about 1.6td b3 wagons in europe, but there were never any in north america, correct?
Seems like the swap is pretty straightforward and all. Is the car too heavy to actually drive it with the td? Anyone around here done it at all? A few people on the tex have done it and report good results.
February 20, 2008, 02:01:56 pm
blkboostedtruck
February 20, 2008, 02:01:56 pm »
A buddy of mine Tom has put in a N/A diesel in his '90 passat wagon ! Tyler (burn your money) will see it this weekend when he goes up to canada!
Tyler should take a bunch of pics. of it and post them? for everyone!
thanks Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
February 20, 2008, 02:11:49 pm
hamradio
February 20, 2008, 02:11:49 pm »
I'm going to guess that it's pretty slow?
February 20, 2008, 02:20:52 pm
blkboostedtruck
February 20, 2008, 02:20:52 pm »
yea ! but he said it sure rides better then a rabbit! little more confy too!
Duane
'66 variant 1500S
February 20, 2008, 02:40:16 pm
hamradio
February 20, 2008, 02:40:16 pm »
that's one of my thoughts. I love my rabbit, but do get a little tired of the old interior. I know, I could make it nicer, but a minimal interior like that fits the car well. It doesn't need to be, nor should it be really nice. I wouldn't put an na in if I did, it'd for sure be a td.
February 20, 2008, 03:31:09 pm
KTZed
February 20, 2008, 03:31:09 pm »
The wreck I got my 1.6TD from was a B3 actually. It had been swapped in there sometime in its life. It looked like it would have been a pretty easy swap. I know I didnt have to change much to put it in my mk2. The passat had an O2A trans with cable shift/hyd clutch so the flywheel and clutch would have to changed over to the O2A style. Mine also had a different alt bracket for mounting the passat AC and power steering. Thats about it I think, other than the regular gas to diesel swap stuff.
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
February 20, 2008, 03:34:37 pm
91MF
February 20, 2008, 03:34:37 pm »
wifey has a b4 passat wagon vr auto[barf] and i've always thought once we can afford to upgrade her that i would swap a diesel into the wagon.
i dunno how much more the b4 weighs than a mk3 but they were diesel so it cant be all bad right?
February 20, 2008, 04:03:09 pm
February 20, 2008, 04:03:09 pm »
I drove (built) a mk3 with a 1.6TD and it wasn't too bad. It had really tall gears so I had to be going pretty quick before I could get into 5th. I'd imagine it weighs the same if not more then a B3 wagon
February 20, 2008, 04:51:37 pm
hamradio
February 20, 2008, 04:51:37 pm »
How tall of gears? Did you use an 02a or whatever, or make an 020 fit? If 020, what code? If 02a or whatever, what would've had tall gears? A tdi trans?
Any vids or anything of it at all? Was it faster or slower than a NA mk1?
February 20, 2008, 05:35:04 pm
February 20, 2008, 05:35:04 pm »
It was an AAZ before the swap so it had an 020. The code was CHD
3.67 3.45 1.94 1.29 0.91 0.75
It's been a few years since I drove my rabbit, which was fast to me but I think the MK3 was faster. I'm sure cruising on the highway above 100 was fine, but 90 was right around the shift point. Pretty high RPM in 4th but too low in 5th to make it up
any
incline without smoking everything out
No videos and it has since been torn apart due to excessive oil consumption
EDIT actually the mk3 was definitely faster
February 20, 2008, 05:49:15 pm
hamradio
February 20, 2008, 05:49:15 pm »
Ok. I was just wondering if it'd be this unbearable monster or not. Sounds sort of like my na- any incline requires 4th.
Sounds like I'll go ahead with it, if I end up buying a passat for sale locally.
Reply #11
February 21, 2008, 08:34:06 am
myke_w
Reply #11 on:
February 21, 2008, 08:34:06 am »
my buddy built one and loves it.. he can cruise all day at 80 no problem with his td..
I say go for it..
Only prerequisite is that it had a 16v in it and not a vr6
Reply #12
February 21, 2008, 12:16:27 pm
91MF
Reply #12 on:
February 21, 2008, 12:16:27 pm »
Quote from: "myke_w"
if you swap k-frame from diesel donor its should be all good, no?
Reply #13
February 21, 2008, 12:29:56 pm
myke_w
Reply #13 on:
February 21, 2008, 12:29:56 pm »
not sure on k frame.. I think a arms are wider - like mk3 jetta, axles are longer like mk3.. think about shifter assemblies, because on a vr they'd be cable, and clutch pedal assy, cause that would be hydraulic on vr..
So basically, the easiest car to swap into is a 16v, not saying it can't be done, but I can tell you it will be more difficult and expensive..
Reply #14
February 22, 2008, 01:35:12 pm
91MF
Reply #14 on:
February 22, 2008, 01:35:12 pm »
agreed.
