Author Topic: Which maniflds fit?  (Read 4543 times)
February 20, 2008, 10:14:12 am
  • 1739
Which maniflds fit?
« on: February 20, 2008, 10:14:12 am »
Just to make sure before i buy the intake, will the exhaust and intake manifolds from an idi fit the ALH or AHU heads i want to get. I seem to think they will?! i already have a exhaust from a quantum, just no motor yet. it's just that i seem to remember that someone mentioned that those motors are not quite the same length.
Reply #1February 20, 2008, 01:12:42 pm
Greasecar
  • 126
    • http://www.greasecar.com
Which maniflds fit?
« Reply #1 on: February 20, 2008, 01:12:42 pm »
All of the TDI and IDI manifolds will bolt up but the port shapes vary a bit.  I have an ALH intake manifold on my 1.6.
www.greasecar.com
79 Mini diesel (1.5 Peugeot)
82 rabbit TD (given to Junkcollector Jay)
84 rabbit TD (intercooled w/ VNT)
82 rabbit PD (undergoing swap)
01 Golf TDI (burned to the ground)
02 Golf TDI (355,000 miles and counting)
04 Passat TDI Wagon (Grocery getter)
Reply #2February 23, 2008, 09:35:02 am
hillfolk'r
  • 1532
Which maniflds fit?
« Reply #2 on: February 23, 2008, 09:35:02 am »
tdi had D shaped intake ports,i didnt think an idi intake would fit
the bolt pattern is the same,though
exhaust ports are the same
im runnin a early 4-2 exhaust manifold flipped upside down on my tdi(minor clearancing needed)
what other engines have a d shaped intake port that we can swipe a better flowing intake from???
heres a pic of a stock intake i cut down
im figuring to tig weld a 3 inch aluminum pipe to it for a log style intake
just a pic for ideas
im probably gonna make 1/4 -3/8 spacers to put the exhaust manifold back a little for more intake clearance
but i may have to modify the firewall for clearance,cause the wastegate is close as It is.....
pic of spacers,cnc machined
heres a pic of a crank breather adapter i made on a lathe/mill,to get rid of the crack prone breather pipe from the 'case to the valve cover
just get some of that 1 inch id clear braded home depot hose to hook it to the valve cover
Throttle cables ftw
Reply #3February 25, 2008, 12:01:39 pm
Which maniflds fit?
« Reply #3 on: February 25, 2008, 12:01:39 pm »
Deo, any reason why you have the exhaust manifold flipped?  I might have a spare dual-port gasser manifold left over. ;) Interested in that adapter plate you made.  :)
Just wondering, as I might need the space above for an intake manifold and I wanted to run the manifold pointed downward.
Reply #4February 28, 2008, 05:55:24 am
  • 1739
Which maniflds fit?
« Reply #4 on: February 28, 2008, 05:55:24 am »
so the intake for a 1.9 should fit . Don't they have square holes?
Reply #5February 28, 2008, 06:13:03 am
Which maniflds fit?
« Reply #5 on: February 28, 2008, 06:13:03 am »
The 1.9 has D ports, just the same as a TDI.
Reply #6February 28, 2008, 09:09:14 am
  • 1739
Which maniflds fit?
« Reply #6 on: February 28, 2008, 09:09:14 am »
perfect, problem solved. thanks everyone
