Author Topic: 130 to 155  (Read 11519 times)
February 18, 2008, 03:14:21 am
dillenger1
  • 777
130 to 155
« on: February 18, 2008, 03:14:21 am »
sORRY,i know this has been covered,but i had some trouble finding a definite answer.Has anyone tried this?If so how did they react with a pump set at Na spec?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1February 18, 2008, 06:37:57 am
Baselyne
130 to 155
« Reply #1 on: February 18, 2008, 06:37:57 am »
So you can use 1.6L injectors that open at 155bar in your N/A?
Reply #2February 18, 2008, 06:49:48 am
Baselyne
130 to 155
« Reply #2 on: February 18, 2008, 06:49:48 am »
Ok wow, I think im beginning to understand...
So even if your going to turbo a N/a it's best to use the reg n/a injectors?
I guess its all about the pump then?
Reply #3February 18, 2008, 09:27:44 am
130 to 155
« Reply #3 on: February 18, 2008, 09:27:44 am »
I ran 130 bar injectors in my turbo for a couple of weeks (as a test to confirm they didn't leak) and had no problems other than the usual signs of a bit too much advance... a bit more rattling that usual, even when warm.  My timing was set to 1.03 at the time.... again as an experiment to see if the advance caused by the lower breaking pressure was noticeable.  It was !!
As another data point.... by 1993 and the AAZ VW switched to 150 bar injectors and static timing of 0.85mm... perhaps in recognition of the impact of higher breaking pressures on fuel economy ? The AAZ is definitely tuned for economy not power, at least initially ;-)
Reply #4February 18, 2008, 03:15:18 pm
blkboostedtruck
  • 1535
130 to 155
« Reply #4 on: February 18, 2008, 03:15:18 pm »
actually the answer he needs? is if you bump 130bar injectors up to 155bar will it work with his N/A pump that has a LDA on it? or should he stay at 130 bar with his injectors that he is having rebuilt with new GTD nozzels?
his injectors are 130bar bodies and internals!
witch is the best way to go?
I thought it was best to stay at 130bar in his situation?
what do you guys think?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #5February 19, 2008, 12:51:47 am
130 to 155
« Reply #5 on: February 19, 2008, 12:51:47 am »
Like most things... I doubt there is a "right" answer.
VW uses higher breaking pressures on their turbo engines... so not knowing any better I'd be inclined to up the breaking pressure if moving to a turbo.   I've read somewhere that the sweet spot for economy on a 1.6 turbo is around 140-145 bar (balance between atomization and pump losses)... still up from 130.  I also seem to recall Mercedes runs their turbo nozzles in the 145 range too ??  Can someone confirm ??
I think the more important thing, regardless of what injectors you use, is to match the static timing to the breaking pressure.
So:
Using 130 bar injectors ??  Use the NA timing specs (0.95-1mm for example)
Using 155 bar injectors ??  Use the turbo timing specs (1-1.05mm for example)
Just my thoughts at the moment... until someone schools me...
Reply #6February 26, 2008, 01:27:13 pm
CrAzY_DrIveR
  • 16
    • MK1 TDI
180
« Reply #6 on: February 26, 2008, 01:27:13 pm »
what about 180 bars injectors?
'80 Rabbit TDI Project - www.mk1tdi.blogspot.com - ARL PD300 in progress...
'89 BMW 324td
Reply #7February 26, 2008, 01:30:36 pm
Re: 180
« Reply #7 on: February 26, 2008, 01:30:36 pm »
Quote from: "CrAzY_DrIveR"
maybe if you want poor mileage? unless you're running a TDI
Reply #8February 26, 2008, 02:30:15 pm
CrAzY_DrIveR
  • 16
    • MK1 TDI
« Reply #8 on: February 26, 2008, 02:30:15 pm »
i'm running 1.6 idi and want more power, so i bought mercedes 300td nozzles and asked a injector specialist to raise the pressure to 180.
I had to remove the pump before fitting the new injectors and now the car won't start, i'll put back the td 155 injectors to check if it works.
If not something strange is going on here  :roll:
'89 BMW 324td
Reply #9February 26, 2008, 02:47:36 pm
130 to 155
« Reply #9 on: February 26, 2008, 02:47:36 pm »
At 180 bar, your timing will be off, and you probably will get less fuel. You should put them back to 150-155
Reply #10February 26, 2008, 02:50:30 pm
130 to 155
« Reply #10 on: February 26, 2008, 02:50:30 pm »
Quote from: "jimfoo"
And your pump losses will go up, resulting in a drop in horsepower and fuel economy.
Reply #11February 26, 2008, 05:23:41 pm
CrAzY_DrIveR
  • 16
    • MK1 TDI
« Reply #11 on: February 26, 2008, 05:23:41 pm »
Quote from: "Vincent Waldon"
It's strange because a friend has his 1.6 idi with 10mm lda and 180 bar injectors with 125hp dyno tested.
It was not enough so now he his running a 1.9 m-tdi  :lol:
http://www.clubegolfpt.com/forum/viewtopic.php?t=11626&start=0
I hope i can at least start my engine  :oops:
'89 BMW 324td
Reply #12February 28, 2008, 05:21:56 am
Giles@PerformanceDiesel
  • 221
    • http://www.performancediesel.ca
Injector pressures
« Reply #12 on: February 28, 2008, 05:21:56 am »
Hey guys
If u run a turbo u need to run the 155 Bar injectors. and 130 for the NA
the reason for the higher pressure was to make sure you don't get
secondary injection caused by the turbo cylinder pressures lifting
nozzle needle off its seat and causing a seconday injection.
hope this clears up
Giles
Reply #13February 28, 2008, 06:03:13 am
subsonic
  • 1836
130 to 155
« Reply #13 on: February 28, 2008, 06:03:13 am »
I never would have thought of that.  So if 155 was for stock boost, what about when we turn up the boost and fuel? :?
Reply #14February 28, 2008, 09:43:34 am
  • 221
Injection timing
« Reply #14 on: February 28, 2008, 09:43:34 am »
Hi again
The injection lines have constant pressure in them during normal running
of the engine all the time.  it is about 200 psi below opening pressure.
so when the combustion starts and the pump has already stopped
injecting fuel then the secondary injection occures because there is
still pressure in the injection lines.
Giles
