Author Topic: my N/A diesel turbo build... 56k warning...  (Read 6957 times)
February 16, 2008, 08:08:45 pm
eightyonerabbit
  • 51
« on: February 16, 2008, 08:08:45 pm »
As some of you may know, i bought an 81 rabbit diesel about 2 or 3 months ago... it had its usual rabbit issues (mostly electrical), but i got most of them fixed (the important ones anyway)... well i decided it was a little too boring to drive because it was a 4 speed manual, so about a month ago i swapped it for an FK with a .71 5th gear... it was more fun, and a bit more responsive, but it still needed something... IT WAS TOO DAMN SLOW!!!
                                so..............
i decided to slap a turbo on that ***...
parts needed for the build:
-K14 TD turbo
-misc. piping
-air filter
-oil lines
-oil pan
-boost gauge
-down pipe - $200 for everything listed so far (i got a deal)...
-MK2 TD intake manifold - $40 shipped
-EGT gauge - ~$50
-EGT probe - ~$30
the necessities:
the motor before:
first we removed the intake manifold, exhaust manifold, and stock d.p....
then we put the new intake manifold on...
then we attatched the turbo...
test fitting the elbow...
after this, we took off the old oil pan and scraped off the old gasket (ugh!)... we used a gasser oil filter flange and put the oil feed line on the top hole (sorry, no pics of that)... we then attatched the old oil pan and the oil return line... after that we put on the downpipe... now its time to get the gauges working... 8)
dash before:
the pig approves.
its all done...  8)
the car (just in case you've never seen it):
thanks for reading
Reply #1February 16, 2008, 08:59:02 pm
tSoG-84bit
  • 188
« Reply #1 on: February 16, 2008, 08:59:02 pm »
looks like you are still running NA injector pump?
I ask because I'm debating putting a NA pump on my TD long enough to get a giles rebuilt TD pump.
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
Reply #2February 16, 2008, 09:02:20 pm
eightyonerabbit
  • 51
« Reply #2 on: February 16, 2008, 09:02:20 pm »
o yea... question...
my EGT's are hitting a maximum of 1200F... could i increase my fuel? if so how much??
Reply #3February 16, 2008, 09:03:16 pm
eightyonerabbit
  • 51
« Reply #3 on: February 16, 2008, 09:03:16 pm »
Quote from: "tSoG-84bit"
it runs just fine, its just not nearly as fast as it would be with a TD pump... i like it tho...
Reply #4February 16, 2008, 09:30:55 pm
tSoG-84bit
  • 188
« Reply #4 on: February 16, 2008, 09:30:55 pm »
I'd be careful to increase fuel too much. Perhaps look into a washerfluid injection system? (homemade methanol/water injection system)
link for info
http://www.vwdiesel.net/phpBB/viewtopic.php?t=10150&postdays=0&postorder=asc&start=0
84bit 1.6na
Reply #5February 17, 2008, 09:47:22 am
eightyonerabbit
  • 51
« Reply #5 on: February 17, 2008, 09:47:22 am »
what about running an oil cooler just between the oil filter flange and the turbo so that the turbo gets cooled a lot?? or would that make the oil too cool to protect the turbo?? thanks for any info...  :D
Reply #6February 18, 2008, 06:19:56 pm
eightyonerabbit
  • 51
« Reply #6 on: February 18, 2008, 06:19:56 pm »
putting on an i.c. this weekend and turning up the boost... do i have to have a boost controller or is there a way to adjust the waste-gate??
Reply #7February 18, 2008, 06:29:48 pm
914turboford
« Reply #7 on: February 18, 2008, 06:29:48 pm »
Quote from: "eightyonerabbit"
I don't think that would make any significant for EGT's, if that's what you're thinking. Cooling the center section of the turbo won't cool the exhaust gasses. Probably obvious and not answering your question. But I don't think you can cool the oil too much to protect the turbo. I would say anything above 150 degrees or so would be safe for the turbo. If you were talking 30 degree oil I think that would be  a problem.
Brian
Reply #8February 18, 2008, 06:36:12 pm
eightyonerabbit
  • 51
« Reply #8 on: February 18, 2008, 06:36:12 pm »
Quote from: "914turboford"
Brian
yea.. i wasnt trying to lower EGT's.. just keep the turbo cooler... any idea on the wastegate question?
Reply #9February 19, 2008, 06:58:03 am
fastvicar
  • 154
« Reply #9 on: February 19, 2008, 06:58:03 am »
We are only about 10 days apart on our TD builds!  Trust me, it's fun with a lot of fuel.  Just one major problem:  I'm now in the middle of a head gasket replacement.  I did a top-speed run on Saturday morning and blew it.  :oops:
Time for a 3-notch HG & head studs.
1981 Rabbit 1.6L TURBO!!  "The Whistle Pig"
Reply #10February 19, 2008, 07:16:20 am
fastvicar
  • 154
« Reply #10 on: February 19, 2008, 07:16:20 am »
You'll want to put something on that valvecover vent hole.  I capped mine with one from NAPA.  I think it ran me about $7.
Reply #11February 19, 2008, 08:48:58 am
eightyonerabbit
  • 51
« Reply #11 on: February 19, 2008, 08:48:58 am »
Quote from: "fastvicar"
are you saying i should just block it off?? cuz i thought it had to breath...
Reply #12February 19, 2008, 12:19:26 pm
89VWdieselGolf
« Reply #12 on: February 19, 2008, 12:19:26 pm »
no your right, it does need to breath... but i would recommend some sort of air breather at least to prevent oil spray everywhere
Reply #13February 19, 2008, 12:37:24 pm
fastvicar
  • 154
« Reply #13 on: February 19, 2008, 12:37:24 pm »
This is what I used to cut the oil spray down:  http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=BK&PartNumber=7354702&Description=Valve+Cover+Breathers
It still steams, but the oil spray is gone from the firewall.  I just cut a short section of 3/4" ID heater hose to connect the two stubs.
Reply #14February 21, 2008, 11:30:50 am
89VWdieselGolf
« Reply #14 on: February 21, 2008, 11:30:50 am »
so are you just running what ever stock boost is?
Have you adjusted your IP at all?
I think i may have to do this if i can find a set-up at the junk yard.... if i can turbo my gasser for $300, i be i can do this for $100 :D
