Adjusting a T3 internal wastegate??
Topic: Adjusting a T3 internal wastegate?? (Read 4791 times)
February 12, 2008, 02:02:22 pm
MontanaGTD
February 12, 2008, 02:02:22 pm »
Anyone got any ideas on how to adjust it? (not on mine - its on another GTD my mates got!)
MK3 Polo G40 - Sold
MK2 Golf GTD in Montana Green - FORSALE
MK2 Scirocco Scala 1.8i - FORSALE
MK4 Polo 6n 16v 5dr with A/C - othercar/wifes learner
Skoda Fabia VRS - new Daily
February 12, 2008, 02:13:40 pm
KTZed
February 12, 2008, 02:13:40 pm »
Adding a boost controller is about the only way I can see since theres no arm to adjust. I built my own boost controller out of various fittings and it works great.
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
February 12, 2008, 02:25:55 pm
subsonic
February 12, 2008, 02:25:55 pm »
There is a spring inside the actuator can. I suppose you could replace it with a stiffer one. The MBC is probably the easiest way to go.
1985 VW Golf 5-spd, 4-door, 1.6NA Bought from orig. owner in Savannah with 42,000 miles.
1980 VW Rabbit LS 5-spd, 4-door 1.6NA almost 450,000miles RIP
February 13, 2008, 09:37:34 am
MontanaGTD
February 13, 2008, 09:37:34 am »
Where does the boost controller tap into as its different to my turbo and i'm still scratching my head! So i took some pics!
This is the Turbo:-
Pics are crappy - but wondered if someone had any info? What turbo is it and where does the controller go? there are NO markings on the Turbo housing anywhere!
MK3 Polo G40 - Sold
February 13, 2008, 10:57:17 am
dillenger1
February 13, 2008, 10:57:17 am »
The controller would be a bleeder valve .The object is to trick the stock wastegate into staying closed.Say your WG starts opening at 9psi. if you bleed some of that pressure off the wastegate wont see 9psi till your boosting lets say 25psi
1.6td in toyota pickup
10mm head ,t3 intercooled.
February 13, 2008, 11:45:47 am
KTZed
February 13, 2008, 11:45:47 am »
Bleeder valves will work but the general consensus is that ball and spring types work better and will allow the boost to build quicker. Look here for a basic explanation.
http://www.geocities.com/chmwatson/FAQs/mbc.html
February 15, 2008, 02:07:13 pm
MontanaGTD
February 15, 2008, 02:07:13 pm »
I already have a boost controller on my GTD, but my mates car has a different turbo layout to mine, just wondered where to tap the controller into on this one!
MK3 Polo G40 - Sold
February 15, 2008, 03:39:05 pm
KTZed
February 15, 2008, 03:39:05 pm »
I have a T3 as well and unfortunately dont have any pics but mine has 2 lines going to the WG can. One goes to the compressor inlet which senses atmospheric pressure, and the other goes to a port in the compressor outlet which senses the boost pressure. I simply cut the pressure line and blocked the pressure side, fed my boost controller pressure from the manifold, sent the controller outlet to the other side of the cut WG line.
