Author Topic: Swain tech group buy  (Read 4747 times)
February 08, 2008, 10:51:02 am
subsonic
  • 1836
« on: February 08, 2008, 10:51:02 am »
I will post this in the for sale section as well.
I spoke to a rep at Swain tech coatings about discounts for group buys from auto clubs etc..  He said they would offer a 10% discount if the total for the work sent in came out to at least $1,000.   I am going to be sending in my pistons for coating.  Looking at the gold coat and pc-9.  It is going to cost me a bit over $200.  Anyone else have anything they want to send in?  Any of you cross post in other groups who may want to send stuff in?  It adds up quick.
Reply #1February 08, 2008, 11:04:46 am
« Reply #1 on: February 08, 2008, 11:04:46 am »
Where would these items be shipped to and is there more info on the company?
Reply #2February 08, 2008, 11:06:04 am
myke_w
  • 1099
« Reply #2 on: February 08, 2008, 11:06:04 am »
Subsonic,
Are we talking ceramic coat here?
EDIT: Duh
Do they have a rule of thumb price per surface area covered?
Reply #3February 08, 2008, 11:51:11 am
subsonic
  • 1836
« Reply #3 on: February 08, 2008, 11:51:11 am »
Here is a link for information:
http://www.swaintech.com/
They have different prices for different coatings and different auto parts.
It does not look like they break it down by sq inches covered, but by piece.
Here is a list of prices I boosted from there site.  Looks like a set of pistons would run about $128 bucks plus shipping to get ceramic coating on the tops, and polymoly on the skirts.  These guys are located in NY state.  They seem to have a pretty good rep.  Cant say if they are better than anyone else, but they have been around for a while, and I could not find any negitive comments on them on line.
I asked the rep about the diesel piston prices.  I explained that I was talking about IDI pistons and not TDI.  He was pretty sure the IDI cost would be under the standard automotive piston cost.
Automotive Coatings Price Sheet
 Prices assume disassembled, clean “standard” parts in good condition. Used
parts can be coated, but a cleaning or stripping charge may apply. Do not send assembled or dirty parts.
TBC – A ceramic Thermal Barrier Coating for engine parts. Applied about .002” thick.
Gold Coat Ceramic Armor – A ceramic Thermal Barrier Coating designed specifically for piston domes in extreme applications such as nitrous, turbo and superchargers. Applied about .003” thick.
Poly Moly – A low friction, anti-seize, self lubricating coating. Applied about .0008” thick when applied to piston skirts.
PC-9 – The latest and most durable piston skirt coating and other applications. Applied about .0008” thick when applied to piston skirts.
PPM – A thin, high load solid film lubricant used for parts with little or no room for a coating. Bearings and other parts are often coated with PPM. Applied about .0002” thick.
White Lightning (TBC-EX) – A ceramic thermal barrier primarily used on the outside of exhaust parts. Applied approximately .015” thick.
BBE – A heat radiating coating to dissipate heat and improve cooling.
Flow Coat – Non-wetable low friction coating.
Pistons
TBC on Dome and Poly Moly on Skirt ……................ $32.00 each
*TBC on Dome and PC-9 on Skirt* ………................. $38.00 each
Gold Coat on Dome and Poly Moly on Skirt .............. $48.00 each
Gold Coat on Dome and PC-9 on Skirt ……............... $52.50 each
Dome Only with TBC ………………………................. $24.50 each
Dome Only with Gold Coat ……..………................... $42.50 each
Skirt Only with Poly Moly …....…………...…............. $14.00 each
Skirt Only with PC-9 ………………….…................…. $18.00 each
Heavy Skit Build up with PC-9 (.002-.004”)…............. $24.00 each
Diesel (4.5” diameter and above) TBC and PM .......... $60.00 each
*Recommended for most applications.
Cylinder Heads - TBC™ Thermal Barrier Coating in Combustion Chambers and on Valve Faces
10 Cylinder (pair) …………………………...........….... $385.00 pair
8 Cylinder (pair) ………………………….................... $290.00 pair
6 Cylinder (pair or inline) ………………..............…... $230.00
4 Cylinder Inline ………………………...............……. $200.00 each
3 Cylinder Inline .................................................... $125.00 each
2 Cylinder Head …………………………...............…. $80.00 each
Single Cylinder (Liquid or Air Cooled) ….................. $42.50 each
Single Exhaust Ports (when coating chambers) ...... $12.00 each
2 into 1 Exhaust Ports (when coating chambers) ....  $18.00 each
Flow Coating for Intake Ports
Single Intake Ports (when coating chambers) ….... $25.00 each
2 into 1 Intake Ports (when coating chambers) ..... $28.00 each
STEALTH COAT ™ is a coating that will allow parts to remain “stock appearing” after coating. Our TBC and PM can be applied in STEALTH form when applied to pistons, combustion chambers and valve faces. Add 10% to standard prices when asking for STEALTH.
Valve and Valve Train Components
Face and Radius Side (TBC) …...…………........ $14.00 each
Face Only (TBC)…………………………….......... $10.00 each
Radius Side Only (TBC)…………………............. $10.00 each
Stem (PPM Low Friction)……………………....... $8.00 each
Valve Springs (Set of 16 PPM Low Friction…..... $125.00 set
Pair of Valve Springs PPM Low Friction ……..... $8.00 each
Solid Cam Follower PPM Low Friction ……....... $126.00 set
Engine Bottom End Components
Bearings PPM Single …………………….......... $8.00 each
Bearings PPM 8 cyl rod; 4, 6, or 8 cyl. Main…. $41.50 set
Bearings PPM 6 Cylinder Rod ……………....... $35.50 set
Bearings PPM 4 Cylinder Rod ……………....... $28.50 set
Crank Shaft Oil Shedding ……………….......... $170.00 each
Connecting Rods Oil Shedding ……………..... $25.00 each
8 Cylinder Oil Pump Low Friction……………... $55.00 each
Intake Manifolds
Bottom TBC Ceramic ………………….......... $110 - 225
Top TBC Ceramic ……………………….….... $110 - 225
Top and Bottom TBC Ceramic …………....... $170 - 300
Top BBE Heat Radiating Coating …….......... $95 - 175
Inside Runners Flow Coating ………............. $125/set
Inside Runners TBC Ceramic …………......... $150/set
Brake Components
Calipers TBC inside, BBE Outside……........ $140.00 each
*BBE cannot be applied to Powder Coated Parts
Pads TBC Ceramic on Pad Back ……......... $15.00 each
Extra Pistons TBC Ceramic ………............. $18.00 each
Rotors High Friction, Low Heat ……….........
 $175.00 each
Miscellaneous Parts for Special Power Coatings
Rotary Rotor faces for TBC Ceramic …....… $150.00 each
Rotary Rotor Gears, PPM Low Friction …… $75.00 each
Transmission Gears PPM Low Friction …… $5 - 25 each
Transmission Shafts PPM Low Friction ….. $8 - 30 each
Ring and Pinion set PPM Low Friction …… $80.00 set
Intercoolers BBE Heat Radiating …………. $125 - 225
Water and Oil Coolers BBE Heat Radiating Quote
White Lightning (TBC-EX) Exhaust Coating
Due to the tremendous variations of part configuration, coating prices are estimates only. Exact pricing is based on the actual processing of each specific part. Used parts can be coated. Stripping paint, rust or a previous coating may require an additional charge. Headers with separate primaries (not held together with a flange) or with separate collectors will cost significantly more than the estimates below.
Nobody can get a coating to permanently bond all the way through an exhaust tube unless it is very short and open from both sides. We do not coat the inside of turbo parts so be sure to let us know if you are sending turbo parts so we can mask them properly. Naturally aspirated pipes may be coated on the inside if it looks like the coating will not interfere with the mounting of the pipe to the head or the mating part. If you have any specific masking requirements, be certain to let us know where you want the part to be masked so we know what you are looking for.
10-Cylinder ……………………….........… $350 - 500
8-Cylinder – Conventional or 180Ί ……… $275 - 350
6-Cylinder ……………………………….... $200 - 250
4-Cylinder ………………………….......... $150 - 225
Subaru Flat Header …………………...... $175 - 225
Cast Iron Manifold ………….………....... $150 - 235
Turbo Charger Housing ……………...….. $ 90 - 125
O2 Housing ........................................ $50 - $100
Down Pipe, Crossover, Collector, etc. ... $30 - 40/foot[/b]
Reply #4February 10, 2008, 10:21:34 am
subsonic
  • 1836
« Reply #4 on: February 10, 2008, 10:21:34 am »
Quote from: "burn_your_money"
Here is the address.
Swain Technology Inc.
35 Main Street
Scottsville, NY 14546
There is some good testimonials from members in the for sale section under the swain title.
I am thinking about sending in my Intermediate Shaft bearings to be coated with there low friction coating.  Will have to think about it and do some more research.
Reply #5February 10, 2008, 11:43:46 am
tSoG-84bit
  • 188
« Reply #5 on: February 10, 2008, 11:43:46 am »
holy cow, what a shopping/wish list!
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
Reply #6February 10, 2008, 12:36:52 pm
subsonic
  • 1836
« Reply #6 on: February 10, 2008, 12:36:52 pm »
Quote from: "tSoG-84bit"
Your worth it!  spend some coin, enjoy life :lol:
Reply #7February 10, 2008, 01:01:25 pm
tSoG-84bit
  • 188
« Reply #7 on: February 10, 2008, 01:01:25 pm »
I just need to figure out what all I need/want for a full rebuild
 :oops:
I'm gonna have to make a list.
edit, I'm afraid it is gonna be pricey.
84bit 1.6na
Reply #8February 10, 2008, 02:23:09 pm
subsonic
  • 1836
« Reply #8 on: February 10, 2008, 02:23:09 pm »
Will the coatings allow you to reuse your pistons, or are the ring grooves / cyl. walls in need of work?
Reply #9February 10, 2008, 02:33:15 pm
tSoG-84bit
  • 188
« Reply #9 on: February 10, 2008, 02:33:15 pm »
I dunno yet, I haven't pulled the block apart. I don't have any place to do so. I'm thinking about buying all new internals and I just gotta find everything first
Any idea on when this will take place?
84bit 1.6na
Reply #10February 10, 2008, 03:37:35 pm
subsonic
  • 1836
« Reply #10 on: February 10, 2008, 03:37:35 pm »
Well, It needs to hit 1000 bucks to get the discount.  I need to get my project rolling though.  I am going to say Sunday Feb. 24th.  Thats two weeks from today.  If you need to order pistons or other parts, you could just have them shipped to Swain tech instead of to your house, and then back out to Swaintech.
Reply #11February 11, 2008, 03:37:59 pm
the4ork
  • 331
« Reply #11 on: February 11, 2008, 03:37:59 pm »
i've been planning on getting my pistons and combustion chambers and valves coated, i bought new pistons but my head is no good. as soon as i find a good mech lifter head im ready to do it.
i was going to use synergy coatings tho but whatever works...
Reply #12February 12, 2008, 09:03:08 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #12 on: February 12, 2008, 09:03:08 pm »
Sounds a bit high to me. I just had my pistons done by a local place and they charged me $105 for all four. Ceramic coated the tops and moly coated the skirts.
Reply #13February 18, 2008, 08:47:50 am
subsonic
  • 1836
« Reply #13 on: February 18, 2008, 08:47:50 am »
I have been playing e-mail tag with swain tech about the group buy.  After the inital e-mail, where they said they would do it if we sent in 1000 worth of parts, they added some more.
"It is not a nuisance to do the work if they come in from individuals, but at
the same time it does not represent a true group buy.
If we cannot gain any efficiencies, it does not make sense to extend a
discount.  We have many forums, owners groups and similar groups of
enthusiast who send us work on a regular basis.  They do not get a discount
just because they are part of a common group.  As I originally explained,
there are a few times where a group is buying everything from one vendor
such as a down pipe.  That vendor ships everything to us and we receive it
all at once.  The person who puts the group buy creates a list as where the
parts will be shipped and that person takes care of payment.
In that type of situation it is a true group buy and some efficiencies can
be gained when we process the parts and in those rare situations we offer a
discount.  If you have that type of situation I can consider a discount.  If
you do not have a true group buy I cannot extend a discount.  It does not
mean it is a nuisance to do the work, nor does it warrant a discount.
Richard"
So it looks like everything gets shipped in in one box, or there is no discount.  I don't know if that approach will work in our situation.
Perhaps if some of you live close enough to each other it could still work.
What do you think.
