Author Topic: more fuel n' air  (Read 2455 times)
April 01, 2005, 05:29:44 pm
sethyboy85
  • 284
more fuel n' air
« on: April 01, 2005, 05:29:44 pm »
84 TD
stupid question... I want more fuel, max rpm bolt or max idle bolt? I moved the max rpm one today and didn't notice a whole lot blacker smoke and I moved it probably 5 threads out and adjusted the cable so it would pull the whole way.
another dumb question, simple grainger vavle (MBC) would work on the wastegate right?
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #1April 01, 2005, 09:28:04 pm
more fuel n' air
« Reply #1 on: April 01, 2005, 09:28:04 pm »
yep grainger valve will work nicely!  run some hose under the dash and control boost while driving down the road :D
hope you have some gauges (egt, and boost) before you up fuel + boost though
Reply #2April 02, 2005, 05:54:20 am
sethyboy85
  • 284
more fuel n' air
« Reply #2 on: April 02, 2005, 05:54:20 am »
yes, I will use a boost gauge I only plan to turn it up to 12ish psi to be safe and add a little bit of fuel so it puff's black but doesn't leave a cloud. (basically how it looks stock just alittle bit more) and I will be intercooling it so these mountains around here I climb don't raise my egt's too much.
